Dropping the fuel tank.
ABZ-Elise
Post by ABZ-Elise » Wed Nov 14, 2007 10:14 pm
As soon as I get back from offshore I'm planning to take the fuel tank out my car to replace the fuel pump. From what I've gathered its a pig of a job but as I don't fancy cutting the chassis so I'll have to do it the right way.
Is there anything I'll have to watch out for when doing it? and is there a right a right and a wrong way to do it?
Kev.
1999 S1 Elise - For Sale
2003 E46 M3 - Sold
Post by Rich H » Wed Nov 14, 2007 10:19 pm
IIRC the RLC had a tank change due to leakage. Andy/Shug/Robin would be your best bet for help!
Post by r055 » Wed Nov 14, 2007 10:28 pm
it gives you the steps in the elise w/shop manual... have you got that?
im sure Robin and co will be along shortly though with some experienced guidance.
R
als 3dr
Post by als 3dr » Wed Nov 14, 2007 10:49 pm
It was me that had the tank out of RLC if you give me a call i will be able to give some advice about doing the job.
SLS - Servicing Lotus's in Scotland
hiscot
Post by hiscot » Wed Nov 14, 2007 10:51 pm
its not that bad a job
run the car very low on fuel before starting
can be done single handed use axle stands to raise car very high ( chock f wheels ) and trolly jack to lower tank dont forget to dissconect the fuel pump hoses before lowering the tank (plastic hoses) from inside the car
fuel pipes are easy with arch linner out, hand brake and gear cables disconected and outa the way
clean the rust/ water from tank whilst off and use very very fine wet/dry paper then switch cleaner on the fuel sender contacts and resistor wires ? it made my usless gauge work again as it had gone quite manky over the years with the fuel ( works like a scalelextric controller ) but be very gentle and rub same direction as the wires
ABZ-Elise
Post by ABZ-Elise » Thu Nov 15, 2007 12:07 pm
r055 wrote:it gives you the steps in the elise w/shop manual... have you got that?
No, but I really should get one :?
hiscot wrote:its not that bad a job
Thats all the info I really need. Should be able to take it from there.
als 3dr wrote:It was me that had the tank out of RLC if you give me a call i will be able to give some advice about doing the job.
Will give you a call if I get stuck if thats ok.
2003 E46 M3 - Sold
Post by r055 » Thu Nov 15, 2007 1:50 pm
get someone up in ABZ to burn you a copy of it.
if all else fails, gimme a shout and i'll mail you one
Post by ExigeKen » Fri Nov 16, 2007 1:01 am
r055 wrote:get someone up in ABZ to burn you a copy of it.
Ross fuel tanks and burn :roll:
Post by Mikie711 » Fri Nov 16, 2007 3:09 am
I've got a copy of the Elise S1 if you want it PM me our addy and i'll drop a copy round.
TBA
Brunty
Post by Brunty » Fri Nov 16, 2007 10:59 am
Had my tank out recently to change the rear brake lines. MOT man thought they looked dangerous - they were fine as it turns out...
I found the hardest part was removing and refitting the fuel filler neck hoses.
(sorry)
and
(sorry)
(please don't post copyrighted material - Shug)
foz01
Re: Dropping the fuel tank.
Post by foz01 » Sun Jun 26, 2011 7:13 pm
After pulling out my passenger seat to disconnect the braided lines as they had corroded at the fittings did I not snap the crappy plastic tank connections, of course I have nearly a full tank, and the engines out, any tips to make life easier or is it going to be an absolute c-unit of a job?
Disconnect filler cap, handbrake and gear cables, anything else, don't have the workshop manual or is it online anywhere?
Every job on this car has taken twice the initial estimate :mrgreen:
Motorsport K20 Elise
Post by tut » Sun Jun 26, 2011 8:19 pm
Changed fuel pumps three times now on the S1 from the top, a one hour job. There is a round access hatch on top behind the pax seat held by four screws which gives access to the fuel pump. It is not part of the chassis and all you have to do is cut out a small tear drop shaped extension to clear the inlet pipe and you can take it out.
Put in the replacement and stick the cut out back on.
foz01
Post by foz01 » Sun Jun 26, 2011 10:14 pm
Ok, I have the access panel there off already, that involved a grinder and a dremal but that's another story :roll:
I did think about cutting it as didn't look like you needed to cut away much, if it's a standard bodge i will just carry on, although will need to plug this broken fuel lines as the smells strong :shock: :mrgreen:
Post by tut » Sun Jun 26, 2011 10:43 pm
Around a 2" tear drop shaped hole on the middle of the car side.
foz01
Post by foz01 » Mon Jun 27, 2011 8:38 am
Just to clarify that's a seperate hole or an extension of the existing opening?
