bigrichi
by bigrichi » Mon Oct 22, 2007 10:47 am
hi guys,
my car has developed an annoying noise.
i have a 55 plate 111r.
ok gonna try and describe this as best i can but forgive the terms cos i'm not a technical person.
mainly happens at cruising speeds. when i take my foot off the throttle (say to slow down but not enough to need the brakes). i think this is called a trailing throttle. there is a very light rattling/tizz.
i thought it was maybe the undertray cos i know on here there has been loads o posts about loose bolts so i gave them all a nip up anyway but still have the noise
i also noticed when i press the clutch in the noise disappears and then comes back when i let the clutch out.
anybody got any ideas cos it is doin my head in
thanks
mrbennybennett
by mrbennybennett » Mon Oct 22, 2007 11:48 am
Mine does that too and its an 06 111r
I have no idea whats causing it - just get used to it after a while or turn the stereo up
I also checke the undetray but it seems nice and tight
Porsche Spyder RS
BMW 128 ti
Audi RS Q3
Ford Fiesta RS Turbo
tenkfeet
by tenkfeet » Mon Oct 22, 2007 12:10 pm
I am sure I read a post saying that the floor sometimes vibrates under the seats and someone had wedged stuff under the seat to stop it. An expert will be along soon I would imagine.
No lotus
Exige Sport 350 (Sold)
Evora S (sold)
Edin430
by Edin430 » Mon Oct 22, 2007 12:16 pm
Third person right here.....
Altho mine happens from what sounds like in behind the dash.... Its the same kind of noise and happens at the same kind of time and actions as what you say...
Getting it booked in with Ali for a few things though so will let you know if he can find anything
by ExigeKen » Tue Oct 23, 2007 7:35 am
My guess is a coin stuck down the cover of the handbrake it makes an awful rattling noise rattles on teh floow and handbrake cover two different sounds - slide a piece of wire under the bottom of the cover and drivers seat to see if you get resistance and can dislodge it.
Failing that Ali os SLS is your man.
Edin430
by Edin430 » Tue Oct 23, 2007 8:42 am
Booked in for the 10th of Nov... So will let you know
MRpunchinella
by MRpunchinella » Wed Oct 24, 2007 6:13 pm
Ive only got an S1
but i had this problem, I pop rivitted two meter long , or so, aluminium strips about an inch in breadth along the underside rear plate, pointing toards the front of the car.
Noise stopped.
Just a penny worth.
Bada Bing!
by Bada Bing! » Wed Oct 24, 2007 7:56 pm
My 111R did the same thing and it was the exhaust heatshield mountings that had rotted and the whole thing was rattling. 6 months later something under there is rattling and I think I have the same problem again.
Gaz
"Ram it baw deep"
pete
- Vexatious Litigant
by pete » Thu Nov 01, 2007 12:46 am
My 111s S2 does this too.
My S1 111S also did it.
Quite annoying.
Appendix E of the owners manual explains it in detail, apparently it's a feature.
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Edin430
by Edin430 » Thu Nov 01, 2007 8:27 am
does it stop when u put ur feet lightly on the brakes?
Bada Bing!
by Bada Bing! » Thu Nov 01, 2007 11:24 am
Mine doesn't. It stops when I kick the back of the car though.
Gaz
"Ram it baw deep"
David Bryce
by David Bryce » Thu Nov 01, 2007 1:44 pm
mine has done the same since I put on the stage 2, I'm pretty sure that it's the exhaust touching the heat shield
- Site Admin
by simon » Thu Nov 01, 2007 2:17 pm
tenkfeet wrote:I am sure I read a post saying that the floor sometimes vibrates under the seats and someone had wedged stuff under the seat to stop it. An expert will be along soon I would imagine.
Solves it on mine.
