There are metal pipes that run up the chasis legs (NS & OS) of the car.
to & from the radiator / engine.
There are rubber hoses for the bends etc, but the long straights are metal pipes.
In the chasis leg there is a square piece of foam which holds the metal pipe in place. I thought that this was worn & the pipe was knocking off the sides - however, i took the tray off & had a wee look. Everything looks OK.
Is there anywhere else that this could be?
It's happening on both sides.......
David
