Back Pads
- craigs135s
Back Pads
My back pads seem to be rattling about i can here them when the window is down. I got anti rattle pads from eliseparts for the front can you get them for the back?
Cheers Craig
Cheers Craig
Europa
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
S2 Black 111r. Gone
S1 Exige. Gone.
S2 111s. Gone
S1 sport 135s. Gone
- craigs135s
- craigs135s
Get the wheel off and see if you can get them to shift with a bit of a tap (avec hammer, protecting the caliper with a block of wood)
Then get the pads out of them - guide here:
http://www.elise-faq.info/content/brakes/padchange.php
Move the caliper along it's slide - you should see the rubber gaiter, is it split? Now, there should be a seal kit which gives you this gaiter, but that's a job for MMC to find (the caliper is shared with the Esprit)
Worst case, if the slides are too corroded, could be a new caliper or two.
Now, that's the most likely thing, can't think of any other reason you could move the outer pads....
- craigs135s
sliding caliper is also the same as the Renault Laguna.
As Shug says if it's the outer pad that rattles then it sound like the slider has siezed.
Bigger issue could be the it's siezed on and has worn the inner pad down.
Either way - it's a job for sooner rather than later.
Ah, well, the jury's still out on the Laguna thing... I think Rox got some Laguna seals for his and they didn't fit. Tho, I think the pin seal did, just not the piston seals. But if it's a replacement caliper, the Laguna might very well not be the one you need.
- craigs135s
- craigs135s
My Green stuff rears rattled until I changed them out (I just replaced them with greenstuff again) & they stopped.
It might of been cos they were a bit thin (still had 2-3mm left) but I think putting a wee bit of copperslip on the backs and pad edge contact points did the trick)
Baggy
Silver S1 111s
The Deen
Silver S1 111s
The Deen
Just found this on Exiges.com
http://www.classicbrakes.co.uk/
These guys can supply a complete seal kit for the rear calipers on the Elise. This includes the dust boot for the sliding pin. Believe it's also ITRO 20odd quid, which is nice.
