Specialist Tools
Specialist Tools
Thought I would put a post up for specialist tools that would be helpful for working on an Elise.
I have:
a rivinut gun
ball joint press (on the car)
wind back tool for the rear brake pistons
If anyone needs to borrow these, please let me know.
I have:
a rivinut gun
i have the S2 2001 k series workshop manual on cd if anyone's wanting a copy
also have a collection of "normal tools"
plus electric saw, jigsaw, sander, table saw, nail gun etc
also work on building sites a lot so have access to big tools should you need to dig a really massive hole or really break something in a demolition sort of way
ninja
ninja
- alicrozier
- Victor Meldrew
I have an electric impact gun... if your nuts are stiff this will sort them out.
Also a liquid extractor, basically a vacumn pump that can suck out lube oil/coolant/brake fluid/other... through a small pipe. Can do an oil change without removing sump plug.
- thinfourth
Marine engineer!!!
Where are you based? I need someone with a sledgehammer to fit a new floor in my arrowflyte and someone of considerable skill to persuade the evinrude 70 not to stall when I floor it after a few minutes sitting at idle ie the time it takes to sort out a skier
rear brake tools
Stephen can you post a picture of the tool so i can make one?
cheers Bernard
cheers Bernard
Dax Rush, westfield, BMW X5 SD M, Mini
