Sometimes I can feel it rocking when braking hard
Drivers Seat
Drivers Seat
It might be my imagination but there seems to be more play (back/Forward) in the drivers seat.
I've had a quick look round and everything seems to be OK. Is there adjustment in the runners to stop this?
Think the runner/adjuster-lock thing mechanism's a bit Heath-Robinson. Mine has done that since new, 8 years ago. Helps you boogie along to Radio 2 though (if you are Robin)
Mine does this too, but only at 1 adjustment place, or at least I can slide the seat back and forward a couple of times and it usually locks into position, might be worth a try?
Chris
Chris
- alicrozier
The shed's seat bolts repeatedly came loose on FF6 (I never did get around to tightening them properly with Loctite (another thing for the list of jobs ed.
I ended up being able to tighten them on the move using the allen key for the roof...
...in retrospect probably not the safest thing to do...
- bertieduff
