I think that means it's his time of the month....tut wrote:"I doubt Alan will be back on here again so Colin has asked me to post some recent pics of the conversion:"
What does that mean Jen?
340R Colin's Honda Conversion
Re: 340R Colin's Honda Conversion
Looks Good Jen/Alan. Great to see everything laid out neatly and not a tool in sight, Id have crap everywhere!
Will you still be ready for the trailer this weekend? If so Sat or Sun?
Cheers Craig.
Cheers Craig.
Hairdresser at heart.
Lots of shiney new things arrived today!! A modified RBC inlet manifold with a custom throttle body.......
Jen
Jen
Keep it coming Jen....
what did you do with the VHPD ?  Does Coline still have it ?
									Emira - Volvo spec
Nope CraigW bought it along with the UCR gearbox, which he is fitting into his 340.
Fitted matetut wrote:Nope CraigW bought it along with the UCR gearbox, which he is fitting into his 340.
Great photos jen, throttle bodies lovely. How much benefit should Colin see with the manifold/body or is sort of experimental?
Alan says that the manifold should give 8-10 bhp. Those manifolds have proven to give good results before.r10crw wrote:Fitted matetut wrote:Nope CraigW bought it along with the UCR gearbox, which he is fitting into his 340.
tut![]()
As for the throttle body, the original doesn't fit. So you can either use an adaptor plate or buy az custom one. Clockwise made that one, any excuse for a bit of billet.
It all should compliment the cams well
Jen
As Jen says, not sure what that inlet manifold is, but the one on the JDM engine which I have on N1 and N3, is worth around 10hp, and a lot of owners fit the JDM one onto their UK spec engines, but also because the standard ones are renowned for splitting.
It's an RBC manifold from a euro Accord Type R. You need to cut a water jacket out and then use a different throttle body or adapter plate. It gives good improvements even from the JDM but will not fit without bulkhead modifications.
I think.
Jen
						I think.
Jen
- Great Pretender
Loving this thread. Good work Jen/Allan.
A Honda Elise is on my shortlist of maybes so I'm keen to see how you both get on.
Incidentally, I've seen the orange Elise about town; it looks awesome
Simon
BMW M3 CSL: flappy paddle spec
Audi TT 225: swmbo spec
						Simon
Ha...it's like someone is putting words in your mouth.jen wrote:It's an RBC manifold from a euro Accord Type R. You need to cut a water jacket out and then use a different throttle body or adapter plate. It gives good improvements even from the JDM but will not fit without bulkhead modifications.
I think.
Jen
Good work all the same Jen
I listen and I type but I only have a vague idea of what it all means!!
Jen
						Thanks!! If you want to see it better, just give us a shout!! Next time you see us out and about, give us a flash!Great Pretender wrote:Loving this thread. Good work Jen/Allan.
Jen
- Great Pretender
Thank you, I may well take you up on the offer - for some hints and tips more than anything. A Blue Peter special would be ideal, but I'd also consider doing the conversion myself if it's economical enough.jen wrote:I listen and I type but I only have a vague idea of what it all means!!Thanks!! If you want to see it better, just give us a shout!! Next time you see us out and about, give us a flash!Great Pretender wrote:Loving this thread. Good work Jen/Allan.
Jen
Don't be scared if you see a guy in a TT flashing at you
Simon
						Simon
