Where for a new K series
Re: Where for a new K series
Post by Andy G » Thu Sep 15, 2011 9:15 am
Giles - just remembered I've a K series sitting at SLS!
Cant quite recall what the story was regarding its history, but i could find out for you?
I think it got the Sport 160 intake on it - but have never driven it, and only seen it once :oops:
GilesM
Post by GilesM » Wed Jan 25, 2012 11:38 am
Hi All
Finally getting around to start this work, I'm hoping to have some time at home from the middle of February, and I don't have any real deadline to get the work done, the car can just sit in the garage until I've finished. I plan to rebuild the engine following Robins suggestions, so thanks to those who had mentioned possible engines, but I'll stick with what I have right now, unless of course I make a right arse of things and need a new engine :oops:
Robin, do you have details of what I need to do to get the KR1 spec head work done, does this need a new head or just getting the old one worked on, apologies for what may seem like dumb questions.
Giles
Post by Mikie711 » Wed Jan 25, 2012 12:12 pm
Send it to Rog at Sabre Heads for him to breathe his magic on :thumbsup
Get him on 01945 585381 / 07773 124 580 or email roger at sabre-heads.co.uk
TBA
KingK_series
Post by KingK_series » Fri Jan 27, 2012 2:43 pm
GilesM wrote:Hi All
Giles
Rebuilding a stock K is a very simple job, just remember to get the head hardness tested with an accurate, freshly calibrated digital hardness tester, do not use a head reading less than 95brinnell. No amount of wishful thinking, PRTs or anything else will prevent you having "HGF" if you use a soft head. Remember also to use an OE gasket, despite some internet talk the Chinese gasket will not work on legacy engines, the ex Rover engineers now working for SAIC are 100% against it's use, and recently reprimanded X-Parts for advertising it as a solution [it is a costed down gasket anyway] and aftermarket gaskets will fail too.
Good luck.
Post by campbell » Fri Jan 27, 2012 11:59 pm
We used an OE gasket on mine, Giles, been good for many thousands of miles. Probably until tomorrow like ;-)
GilesM
Post by GilesM » Fri Feb 24, 2012 5:59 pm
Following a bit of reading, a useful chat with Stu earlier today, and a telephone call to Sabreheads, I think I'm nearly ready to go, just need to sort something out to protect the rear clam while it's off the car, then I hope I can get started, I'm sure it will be a slow process, but I should get there in the end, but not before I think of some more dumb questions.
Does anybody have any experience of this lot,
http://www.deroure.com/?gclid=CJKnioufh ... zAodCAIUzA
Just want to make sure it's genuine Lotus parts before I order anything, but they seem to have the stuff I need, Stu was also looking into a possible supplier.
Post by Sanjøy » Fri Feb 24, 2012 6:05 pm
GilesM wrote:Following a bit of reading, a useful chat with Stu earlier today, and a telephone call to Sabreheads, I think I'm nearly ready to go, just need to sort something out to protect the rear clam while it's off the car, then I hope I can get started, I'm sure it will be a slow process, but I should get there in the end, but not before I think of some more dumb questions.
340 list mentioned them a lot not sure if anyone has bought from them.
Post by BiggestNizzy » Fri Feb 24, 2012 6:08 pm
I have bought some bits and bobs with no problems
GilesM
Post by GilesM » Fri Feb 24, 2012 6:16 pm
BiggestNizzy wrote:I have bought some bits and bobs with no problems
Thanks.
Post by campbell » Sat Feb 25, 2012 2:44 am
Brilliant for parts identification, think I bought a few basic bits from them last year Giles. Robin appeared to rate them also but not clear if based on purchase experience or simply the online parts identification resource :-)
What spec is your Sabre head then ;-)
GilesM
Post by GilesM » Mon Feb 27, 2012 10:41 am
campbell wrote:Brilliant for parts identification, think I bought a few basic bits from them last year Giles. Robin appeared to rate them also but not clear if based on purchase experience or simply the online parts identification resource :-)
Thanks Campbell, I was impressed by the parts identification, and it will make things very easy to just order all the stuff from them, just need to get the engine in bits to check what grade all the important parts are.
campbell wrote:What spec is your Sabre head then ;-)
It will be bog standard, 'onest guv :wink:
ABZ-Elise
Post by ABZ-Elise » Mon Feb 27, 2012 11:54 am
I use to buy all my standard engine parts from Land Rover. Gaskets, oil filters, belts, bolts etc. All OE and wasn't to pricey, they'd also give me a discount if I asked nicely. A lot of parts they kept in stock and if they didn't have it they only take a couple of days to get it.
Kev.
1999 S1 Elise - For Sale
2003 E46 M3 - Sold
GilesM
Post by GilesM » Mon Feb 27, 2012 12:48 pm
ABZ-Elise wrote:I use to buy all my standard engine parts from Land Rover. Gaskets, oil filters, belts, bolts etc. All OE and wasn't to pricey, they'd also give me a discount if I asked nicely. A lot of parts they kept in stock and if they didn't have it they only take a couple of days to get it.
Kev.
Thanks, I was also thinking about that, however I contacted deroure.com and they assured me that their parts are all OE, no after market stuff, I'll probably go with them.
Post by Rich H » Mon Feb 27, 2012 1:01 pm
Deroure are great for parts, not always the cheapest but pretty close for OE parts.
Ordered loads for the Esprit from them mostly because of the linked parts catalogue.
Customer service is pretty good too.
Post by campbell » Mon Feb 27, 2012 1:03 pm
Pentland Land Rover have provided me with some useful standard bits, as have Pentland Components (no relation!) in Sighthill (branches elsewhere too).
PLR have moved from base at Craiglockhart to the "motor village" or whatever it's called, at Newbridge off M8 / M9 underpass junc.
