What's wrong with this K then?!?!
Re: What's wrong with this K then?!?!
Think Dave's stuck half in, half out of a set of biking leathers somewhere just now.
A bit late to this party but feel the need to question this part. I thought it was standardDDtB wrote: Further background info...
Original engine in the car died at around 30k miles. Liners sunk. So a minty S2 engine was obtained which had around 25k miles on it at the time. We used the bottom end from that and put a replacement head on it, which had been lightly breathed upon and had some slightly fruitier cams in it.... So that would be why the head was off it.
1995 Volvo 940SE Estate
Haven't actually done anything further with it at this point.
Current thinking is to source another engine and drop it straight in, then have a play with the current engine by taking it apart and rebuilding it.. and maybe even learning something along the way!
Only question then is, do I drop in a standard unit for cheapness and ease or do I try and find something like a 160 VVC one or A. N. Other that's a bit fruitier than a standard one ....
Or do I just drop it into a professional, throw them the keys, shout "fix that will you!" and then bend over....
KingK_series
DDtB wrote:Haven't actually done anything further with it at this point.![]()
- all mad
just give Stu a bell and arrange a fix -
KingK_series wrote:
- all mad
Get it sorted
(and you can pick my discs up whilst your there
And the correct answer is........
<drumroll>
I broke a piston!!!
Big chunk out of one above the compression ring it would seem.
Clearly I gave it one donkey punch too many... rough love ftw!!!
So.... drawing board out and options now being considered.
<drumroll>
I broke a piston!!!
Well done Dave......
Was never able to achieve that.
- Lazydonkey
Good skills !
Think I can better that (in the dim and distant past)... photo to follow. But, nice one Dave
- BiggestNizzy
160 K-seriesDDtB wrote:And the correct answer is........
Duratec
Honda
Jet turbine
Honda powered drivers make better lovers. Fact.BiggestNizzy wrote:160 K-seriesDDtB wrote:And the correct answer is........
Duratec
Honda
Jet turbine
So just imagine how hot I was when I had two of them.
Getting there with it then.
That was my thought on what had happend to it back in France
Stick with the K, plenty of second hand engines around for sub £500....
Stu
Stu
S1 S160
Caterham 310R
Caterham 310R
I will throw you in a piston(s) with the VVC head
