340R Colin's Honda Conversion
Re: 340R Colin's Honda Conversion
Is it not just the alloy uprights that have common bearing failures with the S1? 340 uses steel uprights at the rear so standard hubs should be okay?
Hairdresser at heart.
You can not ask too many questions on here Ken, always someone willing to answer.
Things are not quite as bad as Alan suggested, as my car with 300hp, which spends much of its life on the track, normally susses them out. I have not had a breakdown for over two years, and the sheered driveshaft was my own fault, shifted from 3 to 2 instead of into 4 on the KH straight at 8600rpm. The offside still had the original BLiNK assembly on from four years ago, and was a much thinner driveshaft than the current ones. It was not the outer CV joint that went, the shaft sheared cleanly inside it.
My biggest problems have been with the boots splitting, again partly my own fault as the exhaust manifold is so close to the drive shaft and transfers heat into the boot. I should have more heat shielding on, but a mod along with the now improved boots seems to have sorted that out. James at Stark is having a complete offside assembly made up for me, and I am sticking with standard Rover outers as he hopes to have it in a few days.
What power and tq are you expecting from your 2.4 when it is completed?
Hopefullyr10crw wrote:Is it not just the alloy uprights that have common bearing failures with the S1? 340 uses steel uprights at the rear so standard hubs should be okay?
Deleted
Ken
Engine out this weekend. Had help from Craig and Alan Dickie which was much appreciated
It was easier than expected as the the many "Lotus Specailists" that have worked on Colin's car only left 3 bolts holding the entire body on.
Alan
P.S This engine removal was sponsored by Brew Dog.
Alan
looks quite a clean lump - has it been replaced recently?
only 3 times last year, don't go there ......r055 wrote:looks quite a clean lump - has it been replaced recently?
Alan
Good job guys. Sorry I never made it up but had ill kids all weekend
How long to get if out?
So....when is the Honda going in?
Blue S2 (sold to the plumber)
Seat Leon Cupra Commuter Car
About 5 hours all in i would say and thats including taking the body off.andyc wrote:Good job guys. Sorry I never made it up but had ill kids all weekend![]()
I'm waiting on parts for the Engine, can't put it in until the engines built. I'm hoping to put the engine in in 2 weeks.
Alan
Woo hoo......ready for Tut Towers then
you going to start doing this for other SErs then Alan?Gourlay83 wrote:About 5 hours all in i would say and thats including taking the body off.andyc wrote:Good job guys. Sorry I never made it up but had ill kids all weekend![]()
Alan
I think I could do this as a job now, had a few people ask.r055 wrote:you going to start doing this for other SErs then Alan?Gourlay83 wrote:About 5 hours all in i would say and thats including taking the body off.andyc wrote:Good job guys. Sorry I never made it up but had ill kids all weekend![]()
Alan
Might do 2 a year just to keep my hand in.
Alan
Alan
I can't do it, i know its easier but I just can't cut the body in half.Scotty C wrote:get the hacksaw outGourlay83 wrote:
Alan
He will just have to take the body off to work on it, of course it will never break down.
Alan
