I'll have a look at work later on.
Fitting S2 Suspention
Had a look at the rack raisers, they would be straight forward to fit, t but hey have a tiny little pop rivet at the bottom and I don't have anything to hand that will fit
Had geo checked this am and tracking adjusted, no wonder it felt odd:
It was:
Toe out
Front 0.29 L 0.07 R
Rear 0.07 L 0.1 R
Camber
Front -0.22L -0.18R
Rear -1.47L -1.54R
Now its all lined up in until I get a proper geo sesh.
Toe in
Front 0.0
Rear 0.11
Camber as above
That will do for a bit. Feels much better.
It was:
Toe out
Front 0.29 L 0.07 R
Rear 0.07 L 0.1 R
Camber
Front -0.22L -0.18R
Rear -1.47L -1.54R
Toe in
Front 0.0
Rear 0.11
Camber as above
Yep, I take it you didn't get my reply then! Tourque settings are 45Nm, fairly tight, but as all the nuts are nylock efforts they won't come undone. Just make sure that everything is nice and tight and there is no movement in each bolt (Indicting that the nut has run out of thread o the bolt)
Steering rack raisers are not being fitted now as the top 10 mm bolt on the rack is too stiff to move. the 8mm one came straight out. So my steering is staying as it is for now....
A tad worrying I didn't get ur reply :-/
Steve Butts says he just 'tightened' em too, so I should be fine. Will have a feel about the morrow just to double check
Put some break pad buffer things on the front pads while I had the whels off, seemed to improve rattle/squeel at first but now the rears are soundin noisy as fook.... course maybe thats just cause I can hear em over the fronts now ! ! ?
scott
scott
Got an e-mail about 1/2 hour ago saying delivery failed:
This is the SMTP Server program at host me.freeserve.com.
I'm sorry to have to inform you that your message could not be
be delivered to one or more recipients. It's attached below.
For further assistance, please send mail to <postmaster>
If you do so, please include this problem report. You can
delete your own text from the attached returned message.
The SMTP Server program
<########@hotmail.com>: delivery temporarily suspended: connect to
mx4.hotmail.com[65.54.244.232]: Connection timed out
