battery problem i think ...
- steve_weegie
Yup, that would indicate the alternator is working fine. Charge it up overnight and see how you get on i guess!
If it goes flat in a couple of days, then the battery is goosed... otherwise if it keeps on working well, just remember to unplug the satnav at night
I unplug my battery from the car when i'm charging it - depending on how your battery charger works, it may send quite a high voltage pulse out that the battery can deal with, but not the car electronics. It will probably be fine though...
Steve
Steve
- steve_weegie
ps.... my old battery started doing similar things... it would be fine for a few days, but any longer and it would leak all its charge and leave me stranded! Luckily i live on a hill so bump starting was nice and easy. Airport carparks however were slightly more of a problem
See how you get on over the next few days
There's a float charge which will vanish really quickly, so I wouldn't worry about that - the real test for the battery is to monitor its voltage during cranking - repeat a few times - it should drop to ~10v during cranking and then recover to 12v - if it drops to less than 8 then the battery is either flat (not in your case as you've just charged it) or shagged.
thanks robin. By cranking do you mean turning the ignition on ?robin wrote:There's a float charge which will vanish really quickly, so I wouldn't worry about that - the real test for the battery is to monitor its voltage during cranking - repeat a few times - it should drop to ~10v during cranking and then recover to 12v - if it drops to less than 8 then the battery is either flat (not in your case as you've just charged it) or shagged.
think im going to pickup a new battery today anyway. Had a look in halford yesterday and there was loads !
Think i will go for a good calcium one. What SIZE, DIMENSION, TYPE do i need to pickup ?
Calcium
V12
Sealed
Size ?
Thanks again
Scott
If you f*ck up putting the battery on you will destroy your car's electrics at vast expense. I say this, because some batteries appear to ship with the poles coloured counter-intuitively, i.e. the black one is +ve ...
Also note that a battery with the same number will be approx same size and similar capacity but may or may not fit into your car, and may have the poles reversed from yours, if you see what I mean.
So, by all means get a replacement (but not from Halfords - any tyres'n'exhausts place will carry a cheaper battery), but don't cock up fitting it, or prepare to take it in the shorts ...
If you're at all unsure, ask the guys in the tyres'n'exhaust place to help - more often than not if they're not busy, they'll fit the thing for you while you chat to them about what an awesome babe magnet the car is
Nice simple test for battery health - simpler than trying to measure voltage during cranking - is to power the ignition on and simply put the lights on full beam for 2 or 3 minutes . . . then switch them off . . . this removes the residual charge and shows you what the battery is really like . . . it should recover to >12V fairly sharpish . . .
Fd
Fd
robin wrote:If you f*ck up putting the battery on you will destroy your car's electrics at vast expense. I say this, because some batteries appear to ship with the poles coloured counter-intuitively, i.e. the black one is +ve ...
thanks for the warning robin ! I got a:
HCB063 440 AMP (from halfords)
as it was the same number that was on the car ... staff confirmed it should be ok.
On car was a 063/3 380AMPS ....
took a photo with me showing all the text on the old one. Got a Calcium one which is 450 amp instead of the 350amp that was there but thats ok i understand.
Both are the same physical size , both 12v (obviously).
Sound ok to you ?
I can upload photos if your not 100% sure.
Sorry to be a pain.
