by alicrozier » Wed Aug 03, 2011 10:03 am
Kev wrote:campbell wrote:What adjustment do the Nitron Streets offer? If they have adjustable platforms, then I believe corner-weighting is good to go. If not, then you are stuck with them as they are.
Yeah they've got adjustable platforms and also an adjuster that alters both bump and rebound damping.
Sounds like you are sorted Kev, doubt you'll need stiffer springs unless you want to optimise for track. Clark Motorsport will be able to set the platforms to give the right cross weights then camber, toe...
- Meat
by Scotty C » Thu Aug 04, 2011 10:00 am
i hope you dont mind me saying, but the back of the bootlid now looks like you have just made a pair of ken and barbie matching swimming pools. I dont have an Elise so have no idea if the water will sit there or not, it just looks like it from the photo's?
izibecoz
by izibecoz » Thu Aug 04, 2011 10:57 am
Think you are right Scotty - Water does tend to sit on a normal s2 rear boot around the top edges, and looking at the pic there is no where for the water to run
Appreciate this is still a mock up - but surely a drainage hole would be required or something..... Or indeed an excuse to go and take it for a burn to "remove" the water from the back
Izi
by alicrozier » Thu Aug 04, 2011 11:02 am
So long as the water is removed by accelerating...braking might give a nice tsunami through the engine slats...
Yeah, drainage required I think...
Woodsport
by Woodsport » Thu Aug 04, 2011 1:08 pm
Yep a drainage hole in each vent will be added, I have noticed though that lotus don't especially seem to care about water ingress looking at the design of the lid, I think they should have really considered some drainage, it's easy to design a lid that breathes heat out but stops most water going in, but these lids just let all water in, far from ideal.
by campbell » Thu Aug 04, 2011 1:10 pm
S1 lids are even more like sieves, particularly with their neat mesh grilles instead of slats
Nice to be able to see the beautifully crafted S1 engine of course
pete
- Vexatious Litigant
by pete » Thu Aug 04, 2011 4:52 pm
tut wrote:
I would expect N1 and N3 to be virtually identical in weight both before and after Honda, both converted by BLiNK , as they are '96 cars and there was only one option in those days. N3 may be slightly heavier with the S/C.
They are twins in respect of MMC discs, Nitrons, original wheels, exhausts, etc.
Yeah 'cos all those holes you added to them have all been repaired to the same standard and thickness
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
- Barefoot Ninja
by tut » Thu Aug 04, 2011 4:59 pm
oooohhhh you are cruel..........
Rosssco
by Rosssco » Thu Aug 04, 2011 6:29 pm
VX simply has 2 large bits a mesh, so Vauxhall / Lotus obviously weren't too bother about water ingress directly onto the engine.. (even though some do end up suffering from soggy ignition modules!
VX220 SC
M135i
Parajet V3 Moster 185
by BiggestNizzy » Thu Aug 04, 2011 7:01 pm
With regards to the boot lock, if it's not water tight the boot will fill up with water (mine has)
Woodsport
by Woodsport » Thu Aug 04, 2011 7:05 pm
This one is water tight, i've even made sure the run offs for the vents go into the engine bay, there won't be any water ingress on this boot.
Kev
by Kev » Fri Aug 05, 2011 7:26 am
Great stuff Paul!! Road testing next week?
S2 Elise ST (V6 spec)
Audi A4 Tdi (Shed Spec)
Discovery 3 (Wifes Spec)
Woodsport
by Woodsport » Fri Aug 05, 2011 7:32 am
Hopefully Kev, the clam/engine lid is the last job, so as soon as they are fitted the car can be driven.
