Robin, the fretting coincided with the liner high point though the height did dip from .0025" (we were using metric feelers, but I can't get my head around mm - I couldn’t get decent repeatability with the vernier and digital callipers - with a .75 x 1.5 x 10" block) to 0.001 next to this point. I am assuming this was a uniform loss of height rather than localised.
The fretting itself was not deep. I cleaned up the head face using the edge of the block; there was still quite a bit of crud on the surface. Once the face was cleaned up the fretting did not appear nearly as bad; using the block over that point there wasn't enough room for a thou feeler. I'd still have that area down as most probably for the sealing failure.
woody[/quote]
Funny how the camera never lies, until it comes to taking pictures of cylinder heads, at which point what looks perfect to the naked eye looks like a bag of sh1te on the camera
The top face of the liner will still be flat (they are hard as nails) - it will be that the liner has moved in the block a bit (or the block has moved around the liner, IYSWIM) and this has lead to the two faces being out of alignment.
However, over all the liner heights are still lower than you would hope for, so whether or not the failure is exactly there, it seems likely that the failure will repeat ...
