Brake fluid and oil change - how easy?
- bertieduff
Can you not reach round the back? Its what I do, brake bleed is about an hour total. Bit fiddly but possible even with a ride height of 150mm.robin wrote:With the 5 spokes you might be able to get enough access with the wheels on - pretty sure you need to remove the wheels for 6 spokes and S2 wheels - might be wrong though - nothing to stop people trying it and finding out I guess!
Ah - never tried it this way - sounds like more of a pain than taking the wheel off.RICHARDHUMBLE wrote: Can you not reach round the back? Its what I do, brake bleed is about an hour total. Bit fiddly but possible even with a ride height of 150mm.
Will top up oil level before this weekend and then go for a weeknight next week for the oil change and brake fluid change, if I can get the stuff in time. Probably Tuesday 24th. If that suits anyone, you're very welcome to pop round to lend a hand / make coffee / provide some jovial banter!
D
D
Should be fine Dezzy just let me know if you get all your parts.dezzy wrote:Will top up oil level before this weekend and then go for a weeknight next week for the oil change and brake fluid change, if I can get the stuff in time. Probably Tuesday 24th. If that suits anyone, you're very welcome to pop round to lend a hand / make coffee / provide some jovial banter!
D
Not when I have to find some blocks to drive on, find the jack, find a piece of wood for the jack top, find the wheel brace and (Take note Shug!)a torque wrench before I even start... My way I need an 11mm spanner, my eazibleed kit, the spare from the Porker and some fresh fluid.....robin wrote:Ah - never tried it this way - sounds like more of a pain than taking the wheel off.RICHARDHUMBLE wrote: Can you not reach round the back? Its what I do, brake bleed is about an hour total. Bit fiddly but possible even with a ride height of 150mm.
Goes without sayingrobin wrote:Do worry about the oil level though - too many of these toyota engines have gone pop already!campbell wrote:
Don't worry about either of these before the Campaganza.
They don't call the K "agricultural" for nothing you know...
Campbell
- Victor Meldrew
- Victor Meldrew
Might try to get over. Could turn into a mini sponges at your place...dezzy wrote:Will top up oil level before this weekend and then go for a weeknight next week for the oil change and brake fluid change, if I can get the stuff in time. Probably Tuesday 24th. If that suits anyone, you're very welcome to pop round to lend a hand / make coffee / provide some jovial banter!
D
You're more than welcome, but as for a mini sponges . . . my entire driveway is covered in chuckies, so ain't suitable for jacking. Can get 2 cars in the cul-de-sac outside though in the street. That's where I usually jack the car to work on it. Might p!ss off the neighbours, but I dinnae care!John Reid wrote:Might try to get over. Could turn into a mini sponges at your place...dezzy wrote:Will top up oil level before this weekend and then go for a weeknight next week for the oil change and brake fluid change, if I can get the stuff in time. Probably Tuesday 24th. If that suits anyone, you're very welcome to pop round to lend a hand / make coffee / provide some jovial banter!
D
Will confirm in the next couple of days if I'm going to do this on Tuesday and will PM you my address.
- Victor Meldrew
Dastek have the oil..dezzy wrote:Okay, Halfrauds is truly pants! They don't have the oil or brake fluid I want and the guy who served me was an ignorant little swine.
So, where do I get Silkolene oil and Castrol Super Response (or AP Racing) brake fluid?
D
Halfords had the brake fluid in stock last time I was in the Kirkcaldy store
