Engine Rattle
Post by Rich H » Fri Jun 01, 2007 12:19 pm
Ooops.... :shock:
Post by simon » Fri Jun 01, 2007 12:54 pm
Ah, oops indeed :(
Post by Rich H » Fri Jun 01, 2007 1:00 pm
Big valve head isn't it? HTF did you manage that?!?!
(Assuming it's a bent valve that is)
I'll swap you a servicable standard head for your broken PTP one if you like, I'll even throw in a spare set of std cams, std pulley and a placcy inlet manifold if you want! :lol: :wink:
Post by mac » Fri Jun 01, 2007 2:51 pm
RICHARDHUMBLE wrote:Big valve head isn't it? HTF did you manage that?!?!
It's quite simple when you confuse piston/valve contact for compression and just muller the engine over with a 3 foot bar :oops:
Anyway - putting the standard head on means only one thing - less place for folk to hid when Mandy passes them on the track next Friday :wink:
Post by Rich H » Fri Jun 01, 2007 2:54 pm
Ah, whoopsie :(
How bad is it? Salvageable? At least it wasn't running at the time.
My crank bolt was tightened against the valves on number 4 but I seem to have got away with it for the moment (That was 5k miles ago!) :shock:
Post by mac » Fri Jun 01, 2007 2:58 pm
Doesn't look too bad - would appear to have bent just as the stem starts to widen.
Plan is to run standard for a bit until we've got the spare cash for an emerald and then send it down to DVA and bring it from stage2 to stage3 spec.
Post by Dominic » Fri Jun 01, 2007 4:18 pm
mac wrote:Doesn't look too bad - would appear to have bent just as the stem starts to widen.
Don't want Mandy getting too much power :wink: :lol:
Post by Rich H » Fri Jun 01, 2007 4:24 pm
How bent is it and was there any damage to the piston crown? Will it come out ok?
Post by mac » Fri Jun 01, 2007 5:02 pm
Rich,
There wasn't even a witness mark on the piston crown - it's bent enough to notice that it doesn't close fully - should come out fine at the valve still opens when the cam is rotated - it's just doesn't close fully.
Post by Rich H » Sat Jun 02, 2007 8:58 am
Cool, got away with it then! (Sort of!) :thumbsup
