Sticky Clutch Pedal (S1)
Tom
Post by Tom » Wed Apr 11, 2007 10:29 am
GregR wrote:Don't worry about GT85, its actually teflon (Poly-tetra-flouro-ethene)based not graphite :)
Whatever you do, do not use WD40 :)
sorry matey :D :D :wink: geek faction
Polytetrafluoroethylene (PTFE) is a synthetic fluoropolymer which finds numerous applications blah blah etc
1995 Volvo 940SE Estate
Post by GregR » Wed Apr 11, 2007 10:37 am
spot the Google'er :P
Post by campbell » Wed Apr 11, 2007 10:47 am
Great, cheers for that Greg!
And at least I did know not to use WD, thankfully :oops:
Tom
Post by Tom » Wed Apr 11, 2007 10:48 am
GregR wrote:spot the Google'er :P
from wikipedia, but I also studied chemistry at GCSE, Higher, and Uni......
not that i'm being pedantic or anything...... :leave
MacK
Post by MacK » Wed Apr 11, 2007 12:46 pm
Why not use WD40?
Post by GregR » Wed Apr 11, 2007 12:53 pm
something to do with the fact it ands up breaking down the rubber of seals etc John
Post by Rich H » Wed Apr 11, 2007 1:06 pm
And it evaporates leaving a sticky mess everywhere...
If you must use spray grease use white (Lithium) grease stuff. WD40 is water dispersant and penetrating oil.
Gazbo
Post by Gazbo » Sun Apr 22, 2007 4:23 pm
I've just started to have this problem too, sticky/droopy cluth pedal that I had to hook my toes behind and pull up followed by some pedal pumping before I could get gears again. Do we have a definative lubricant to use on the bushes/pivot points? GT85 or 'dry lube'?
'Climb aboard the shopping trolley of chaos'.
Post by GregR » Tue Apr 24, 2007 1:30 pm
either, but Dry Lube seems to be the one Mac recommends :) Either will do the job IMHO :)
Kelvin
Post by Kelvin » Thu Apr 26, 2007 12:10 am
I had a similar problem for a few years and used dry slide as Lawrence suggests. Eventually I replaced the clutch trunion with the one Geary sells and no troubles since.
Kelvin.
Post by campbell » Thu Apr 26, 2007 8:06 am
Kelvin wrote:I had a similar problem for a few years and used dry slide as Lawrence suggests. Eventually I replaced the clutch trunion with the one Geary sells and no troubles since.
Kelvin.
What is the replacement procedure like? I imagine some serious upside-down-in-the-footwell stuff? Though you are dinky and lithe enough to be able to walk right in there I suppose ;-)
Post by Rich H » Thu Apr 26, 2007 8:12 am
The clutch trunnion I got from geary is pretty sloppy in the plastic bearings so I didn't fit it in the end. simply adjusting the preload on the master cylinder fixed my squeaky clutch.
Gazbo
Post by Gazbo » Thu Apr 26, 2007 5:17 pm
The car is going in for an 'A' service in a couple of weeks so I'm having the trunnion etc replaced to stop the squeak more than anything!
Post by robin » Thu Apr 26, 2007 6:23 pm
Prepare to be trunnioned by the bill for replacing the trunnion ;-)
BTW, I cannot remember who, but someone (perhaps a Lotus employee) once said that trunnion was the engineering term for a widget - i.e when you've run out of proper words, like gudgeon, bush, spline, spigot and so on, all you're left with is trunnion, so that's what it's called ;-)
Post by GregR » Fri Apr 27, 2007 11:45 am
robin wrote:Prepare to be trunnioned by the bill
:sex
