Doesn't seem to be as clear cut as this. If you read through all the threads you'll find that this is the standard Lotus answer to cover up what appears to be a problem with their dodgy A-spec software.simon wrote:There still seems to be some problem with aftermarket induction kits, that would be the first thing I'd get rid of.
MIL light
- SteveBanks
- Novice Racer
Yes, but presumably you mean all aftermarket induction kits, not just the pipercross?simon wrote:I was replying to Steve's post.Novice Racer wrote:Actually ran for months without a problem with the Hurricane. MIL light came on when I started the car to drive it off Robin ramps immediately after exhaust fitting, so I doubt whether the Hurricane is the route of the problem.
NR
NR
Ipsa scientia potestas est
S2 Elise
S2 Elise
Because all they do to go from A-to-B is wipe it clean, stick on a B sticker and program some new code into the ECUSteveBanks wrote:I just noticed that the other day on the B&C site, I was under the impression that you had to pay £900ish so this is good news. Pain in the arse to send back though as I'll be without a car and at the mercy of Dealer/Lotus Motorsport. Why can't you just get a dealer to order one for you, go in to pick it up when it arrives and exchange for your old one at the same time? Would be a lot easier for the customer. I take it you like the change?ryallm wrote:Contrary to popular belief if you have an A spec ECU you don't have to pay quite the full whack
Mark
- SteveBanks
Would not surprise me.robin wrote:Because all they do to go from A-to-B is wipe it clean, stick on a B sticker and program some new code into the ECUSteveBanks wrote:I just noticed that the other day on the B&C site, I was under the impression that you had to pay £900ish so this is good news. Pain in the arse to send back though as I'll be without a car and at the mercy of Dealer/Lotus Motorsport. Why can't you just get a dealer to order one for you, go in to pick it up when it arrives and exchange for your old one at the same time? Would be a lot easier for the customer. I take it you like the change?ryallm wrote:Contrary to popular belief if you have an A spec ECU you don't have to pay quite the full whack
Mark
Mark, who did you deal with for your upgrade and how long did it take? All reports seem to be positive but people tend not to like admitting to spending lots of money for little return so convince me it's worth doing
And before anybody thinks this is an extreme and expensive way to switch off my MIL light, I was seriously considering upgrading before the bloody thing came on. The problem might not be induction related anyway so I still need to get my a-spec read first.
My MIL light came on at the weekend, one week after fitting the Hurricane induction kit to my Toyota-engined car. After AndyG read out the code (P0171, System Too Lean), we switched the MIL back off and it hasn't came on again (touch wood!).
I contacted the manufacturers of the Hurricane (via Eliseparts) and they said that this is the first they've heard of this and that they've sold plenty of Toyota engine Hurricanes without any such problems. They said it could be because the MAF sensor wasn't re-connected properly, but I'm pretty sure it is.
Lotus told me before fitting it that I wouldn't need any ECU adjustments for fuel mix, etc. However, when I called them after the MIL coming on, they denied all knowledge of this.
I think they simply just can't comment on aftermarket kits from a legal point of view, so just want to cover themselves by denying all knowledge.
Our resident expert, Dan, has however informed me that the ECU will now adjust the fuel mixture after getting that error and that the MIL will now not come back on.
Lots of conflicting info there, but I'm definitely going with what Dan has advised. I don't know much about this, so could be wrong, but it sounds like the increased airflow causes a "System Too Lean" MIL error, but following the reset of the system after this error is read out, the ECU adjusts the fuel mix accordingly and so this shouldn't re-occur.
My 2p on induction-related MIL problems on Toyota-engined cars!
D
D
- SteveBanks
I think it re-checks the error status each time you switch the ignition on Steve. Did it go off after re-starting the engine or did it just go off while you were driving?
If it doesn't come back on, I would assume you probably don't have a problem, but remember I know nothing about this!
- SteveBanks
- colin adams
Sounds a very familiar story. I have a pipercross and stage 2 on mine. MIL light kept coming on and going away occasionally. A few visits to MMC later they replaced the olde A-ECU with a B-spec one (free despite the fact we had by then gone out of warantee). So far the light has stayed out. Did not check to see if the bulb had also been removed.... colin
