Gonna pay a visit to kwik fit tomorrow to see if they can get them out with a gun. The other problem is the bit that's stuck in the bolt. I drilled into it last night and the put a screw in and tried pulling it out but it won't budge. Not sure how it's gonna come out
Wheel nuts
- offshorematt
What extra long bar?
I'm giving kwik fit a miss as there's no point cos I wouldn't trust them to fit the tyres. So I'm going to see Ronnie at Wheels Around tomorrow at 10.00. Unfortunately, the 2 adaptors I ordered from Lotus didn't turn up so I'm borrowing Phil's. Hopefully they'll come off with the impact gun.
Went to see Wheels Around in Bridge of Earn after borrowing Phil's spline. Still no luck
Got all 3 normal bolts off the right and 2 off the left but the 3rd one sheared the spline. The locking nuts won't shift at all so they're gonna get drilled out. I currently have the 5 that shifted replace with normal bolts but with a slightly too big head on them (19mm instead of 17mm). Ronnie is going to order a set of bolts with a 17mm head and once I've gotten the 2 splines I ordered from Lotus, they're going to sort it out.
Incidentally, the other guy that was there (didn't get his name) went out to see if he could find a spline that fitted. He couldn't but while he was in Perth he met someone he knew who worked at McConechy's who told him they will not touch an Elise if it had the standard bolts on it and he didn't know anyone in Perth that would either! He also said they'd been through loads of these adaptors in the past and that's why they won't do it. So a word of warning for anyone with these bolts, check you can get your wheels off and if you can, I'd replace with normal headed ones.
Si, this is MMC's problem surely. They fitted the Toyo's right? And the car gets serviced there so the wheels should have been off then too. So they were responsible for ensuring the wheel hubs were greased and the bolts were torqued to the correct spec if they were last to put the wheels on. And even if some Kwickfit guy came in to do the job, it's still their responsibility. Take the car there, scream your head off, and launch the keys over the counter.
lo
On behalf of Si - can he borrow someone else's spline?
Its for the non-stuck wheels.
Lotus have a backorder on this part - and both his and my splines are knacked.
He assures it wont be broken.
If you let me know (Si doesnt have internet acces at work) then I can pass on his Address and you could post it to him?
cheers
Phil
cheers
Phil
Phil
Ford Focus Sport
Ford Focus Sport
Guys,
I just had a look at the photo Si posted again and came up with the attached link which is worth you guys with S2's keeping a hold of.
http://www.bimecc.it/
