S1 S160 no starty
Re: S1 S160 no starty
Post by rossybee » Fri Sep 13, 2024 9:35 pm
He didn't no.
He had all the plugs out so if there was water in there it's now in the bores :damnfunny
Post by rossybee » Sun Sep 15, 2024 5:30 pm
Good news! She lives! :mrgreen:
Did a bit of basic (all I'm able to do) autosparking - AA man said there was a weak spark, replace the plugs but I thought a weak spark would suggest further up the line so took the dizzy cap off, cleaned the 4 connectors and the rotor arm, skooshed with WD-40, all back together and bosh, she fired.
Have plugs on order, will get a new dizzy cap and rotor arm and hopefully that'll do it.
All relatively inexpensive 8)
Stu160
Post by Stu160 » Sun Sep 15, 2024 6:39 pm
The caps can be an issue ...can get dampness inside.
S1 S160
Caterham 310R
Post by rossybee » Sun Sep 15, 2024 7:02 pm
Might go for magnecor leads too
Kinger
Post by Kinger » Sun Sep 15, 2024 7:08 pm
Beware, the lead to the coil is a bitch to remove and refit. A bit of skin loss from above or easier access from underneath with under tray removed.
Post by Stephen » Sun Sep 15, 2024 7:58 pm
Great that she is going
basil
Post by basil » Sun Sep 15, 2024 8:32 pm
Good stuff
Post by rossybee » Tue Sep 17, 2024 1:00 pm
New plugs, dizzy cap and rotor arm fitted.
Now runs much smoother, got it up to temp and it's just much cleaner and less coughy (I thought this was a Sport 160 trait) around town.
Happy bunny, thanks all for the hints and tips 8)
