Replacing a radiator
T6 KFR
Re: Replacing a radiator
Post by T6 KFR » Fri Oct 23, 2015 11:38 am
Radiator and towing strut ordered . Now get MMC to fit during recall work in two weeks ..... See how that goes without Craig there :-(
Post by Corranga » Tue Oct 27, 2015 12:32 pm
good luck, hopefully you won't need it and common sense will prevail!!
Post by mwmackenzie » Fri Oct 30, 2015 12:24 am
Booked in on Monday with Craig to get mine fitted and heater resistor sorted :thumbsup Already have a shiny chrome tow post, anything else I should be thinking about once the clam is off? :?:
neil
Post by neil » Fri Oct 30, 2015 8:14 pm
Fans + mounting brackets are the only other things I can think of if you're doing the tow post, radiator, and resistor pack anyway.
Exige V6
Post by Corranga » Mon Nov 02, 2015 9:50 am
Horn is usually the next suggestion?
Post by Sanjøy » Mon Nov 02, 2015 1:22 pm
Corranga wrote:Horn is usually the next suggestion?
Big ol air horns.
