Brake imbalance
Re: Brake imbalance
Glad that fixed it
It's all too easy to assume pads are good until they wear out. They can degrade for many reasons - and not always evenly.
Re: Brake imbalance
My elise was 749kg with a full tank of fuel and the rear window removed.Mike Scib wrote:Well looks like the pads may have fixed the problem after all now that they have been properly bedded in! Now running DS2500's.
The brake tester also weighs the car, not sure how accurate it is but 780kg with an empty tank of fuel. What does a Elise/Exige SC weigh roughly?
Mike
Re: Brake imbalance
Did some googling and don't think those numbers are right for the vx!Dominic wrote:My elise was 749kg with a full tank of fuel and the rear window removed.Mike Scib wrote:Well looks like the pads may have fixed the problem after all now that they have been properly bedded in! Now running DS2500's.
Mike
(that's why I think Mike will do fine, that and his lack of imagination).![]()
Re: Brake imbalance
Mike Scib wrote:Did some googling and don't think those numbers are right for the vx!Dominic wrote:My elise was 749kg with a full tank of fuel and the rear window removed.Mike Scib wrote:Well looks like the pads may have fixed the problem after all now that they have been properly bedded in! Now running DS2500's.
Mike
definitely not right. standard car is 850kg + supercharger and cooler. Might have a few lighter bits like wheels etc., but not enough to drop it 100kg.
Re: Brake imbalance
There is a long post about weigh in as Craig organised a session between Aberdeen and Glasgow.
This was a summary but the post has attached spreadsheet.
All cars were with absolute full tanks no drivers but apart from Exige none included roof.
2000 340r carbon fibre wings 678Kg
2008 s2 111r 888kg
1998 S1 135 749kg
2004 S2 111S 820kg
???? vx 2.2 886kg
2006/7(?) s2 111r with aftermarket s/c 876kg
2005 s2 exige 914kg
???? s1 honda s/c 764kg
2011 211 757kg
2000 340r honda (lightened) 713kg
2001/2(?) s2 k long roof 782kg
2008 s2 111r 888kg
1998 S1 135 749kg
2004 S2 111S 820kg
???? vx 2.2 886kg
2005 s2 exige 914kg
2011 211 757kg
- Lazydonkey
Re: Brake imbalance
On the same day Dom weighed his (when he threw most of the stuff that wasn't bolted on to one side
) my / your old car weighed in at
With just under a full tank of fuel
EDIT : That was mine above.....2003 VX
Re: Brake imbalance
Something not right - should weigh ~900kg - Standard ~875kg + ~25-30kg of Stage SC parts (I've weighed them all individually..)Mike Scib wrote:
Mike
Elise / Exige S2 SC weighs ~900-930kg
What spec Cl pads were they Mike? - I was thinking of installing some CL5+ (which I really rated on my last car)
VX220 SC
M135i
Parajet V3 Moster 185
M135i
Re: Brake imbalance
Looks like the weight was a good 100kg out then
Pretty sure it was the CL6's Ross, welcome to try them out incase they work for youRosssco wrote:
Re: Brake imbalance
The massive sunglasses, tin of boiled sweets and the travel blanket would have weighed it down though.
- Lazydonkey
Re: Brake imbalance
Re: Brake imbalance
CL5+'s. John got the same ones as I have on mine.Mike Scib wrote:Looks like the weight was a good 100kg out then![]()
Some videos here http://www.youtube.com/user/lou924/vide ... &flow=grid
Re: Brake imbalance
Yep, that's what it says on the front...Lazydonkey wrote::
VX220 SC
M135i
M135i
Re: Brake imbalance
Lots of weight info here
http://wiki.seloc.org/a/Elise_weight
