I'll admit there is a high chance I'll break downtut wrote:Hopefully you will see it on the 30th as I pass him.![]()
Got maps from Bernard but the engines had so much work done, reference the head and turbo setup it was not all that close for fuelling and needed a fair bit of work on the rollers. I've left the ignition map alone, it should be pretty close.
From now though since the fuel pressure is linked to boost I should be able to just adjust the boost tables and the fuelling will take care of itself. I've got a wideband fed in so can monitor the fuelling, if its needs adjusted its not that difficult.
Away for the next week so be a while before I can even play,
Craig.
PS had the go pro fitted so have some vids, not sure when I'll get a chance to post though.
