Hub Carrier Bolts
Post by robin » Fri Aug 18, 2006 7:04 pm
two4oneuk wrote:Just got a full set of uprated 12.9 spec bolts for front and rear the huge price of £2.00 for cash at bolt stockist in Aberdeen.
Different issue - in order to convert from M12 to M16 bolt kit you also need a bunch of funny shaped washers, etc. Geary charges 30GBP per wheel = 60GBP per car. You can have my set for 30GBP.
Post by Rich H » Fri Aug 18, 2006 8:15 pm
Is it any more involved than remove the old ones (!) and replace? OR do I have to take the hub to bits entirely?
Post by robin » Sat Aug 19, 2006 9:56 am
RICHARDHUMBLE wrote:Is it any more involved than remove the old ones (!) and replace? OR do I have to take the hub to bits entirely?
Nope, undo old ones and put in new ones. Hub should stay on, no need to replace bearings.
BTW, I don't reckon you need to replace unless (a) you're eating wheel bearings or (b) you're doing a lot of track days. The original parts are fine for road use and some track use on road tyres.
Post by Rich H » Sat Aug 19, 2006 10:02 am
I'll leave them for now then I drive like miss daisy most of the time.. :oops: :lol:
