What's your old transmission oil like?
Re: What's your old transmission oil like?
Post by BiggestNizzy » Wed Feb 09, 2011 6:01 pm
I used prestige fabrications in East Kilbride.
Post by Mikie711 » Wed Feb 09, 2011 6:04 pm
Was that supply and cut or just cut?
Post by BiggestNizzy » Wed Feb 09, 2011 6:10 pm
Supply, cut, bend and rivit the thing together they are from what I can gather a sheet metal fabrication shop so should be able to do anything. My old man deals with them on my behalf as he works next door.
Post by Mike Scib » Wed Feb 09, 2011 8:00 pm
Scotty yours is not made out aluminium, Marine ply of some sort :thumbsup
Post by Mikie711 » Wed Feb 09, 2011 8:09 pm
The splitter is made of ply but pretty sure the under tray is still aluminium.
Post by tut » Wed Feb 09, 2011 8:57 pm
Just ordered 5 litres of gearbox oil from Opie Oils.
MacK
Post by MacK » Thu Feb 10, 2011 12:03 am
tut wrote:Just ordered 5 litres of gearbox oil from Opie Oils.
Do SE have an arrangement/discount code to use with Opie Oils?
Post by campbell » Thu Feb 10, 2011 12:11 am
Scotty C wrote:
my car looks like this just now :roll:
Hang on a minute...that's...that's...LIGHTNING MCQUEEN :damnfunny
Post by campbell » Thu Feb 10, 2011 12:14 am
BiggestNizzy wrote:the S1 untertrays are 1.6mm sheet, I got my local water jet cutter to make me rear diffusers for much cheapness, all he needed was a DXF file.
AHA. I was just thinking of a fresh bit of Alu under there, actually, as mine was already getting tired before Robin had to tin-snip it to make the new S2 zorst system upgrade thingummy fit correctly :-)
What ££ would you / mate want for a full rear undertray from sheer panel back, totally standard apart from slightly wider aperture for the flexi joint (wot got tin-snipped) ?
PM me if easier / less embarrassing ;-)
Campbell
(getting into restoration mode I think, faction)
Post by tut » Thu Feb 10, 2011 12:15 am
I registered on the site and received a discount straight away. I did not check for S_E as LOT and SELOC came up, so just had to put my nickname in.
Post by campbell » Thu Feb 10, 2011 12:15 am
On the g'box oil front, UJI's has never been changed, don't think it's a service item, but my 'box is getting a little whiny (fnarr) and I have certainly heard tell that fresh oil can help.
Thoughts anyone?
Post by Ferg » Thu Feb 10, 2011 12:29 am
:wink:
Shug wrote:Massive improvements in noise and smoothness with regular oil changes though.
Post by campbell » Thu Feb 10, 2011 12:38 am
Wasn't sure if that only applied to the Yota boxes? I am getting a bit tired right enough...!
Post by BiggestNizzy » Thu Feb 10, 2011 8:58 am
campbell wrote:What ££ would you / mate want for a full rear undertray from sheer panel back, totally standard apart from slightly wider aperture for the flexi joint (wot got tin-snipped) ?
Campbell
Honestly I have no idea my extended 4 fin diffuser cost me £50 fully built. If I can get detailed drawings (DXF/DWG) I can pass them on and get a price.
Post by Dominic » Thu Feb 10, 2011 10:43 am
Campbell
Any piccies?
