Sorry Scotty - but that is the right way - do a search on here or SelC*cks29ttc wrote:Right come on Rich what you been on this morning hahahaAnyone got serious answers for ECU reset
Starting Problem
Re: Starting Problem
Caterham Roadsport 190
Tesla Model 3 LR RWD
Yeah don't think thats ECU thats the IACV reset thing? Suppose thats all I need to reset anywaysRich H wrote:
Macs answer is right. Believe it or not.
Electrics on, gas pedal to the floor 5 times or more, electrics off.
ECU reset.
Now do you trust me...
1999 S1 Elise 111S - Fun Spec
Watch me run around the car shutting all doors and bonnet within 5 seconds hahahaRDH wrote:Sorry Scotty - but that is the right way - do a search on here or SelC*cks29ttc wrote:Right come on Rich what you been on this morning hahahaAnyone got serious answers for ECU reset
Believe it or not, I seem to remember reading there is a sequence with the S2 where the door has to be open (I don't think you have to shut it as part of the procedure though...)
I take it not.
Can picture it. Right Dad you ready 3,2,1 go go shut shut shut 5,4,3,21, thats us
You do need to open the drivers door, for the reason I mentioned above. There's a switch on the door that turns the interior light on, it's also connected to the ECU.
The ECU works everything in the engine from the Throttle Position Sensor to IACV with inputs from the MAP sensor and the O2 sensors.
The S2 are "self learning" where as the S1 isn't.
When you do the reset - you must leave the engine to warm up on it's own (best to do it when it's cold) don't be tempted to jump in and assist with the throttle or it will always require that assistance, similarly if it sounds like it's going to stall - leave it, it should kick in the anti-stall and pick up the revs if it doesn't and it stalls just re-start the engine without pedal assistance.
Now this is important! When the car is up to temp and the revs have settled down, take it for a good hard run - the ecu recalls the setting at all the throttle positions after a reset so if you drive like a granny then the car will basically run like a grannies car and when you want to thrash won't re-act quite so quickly.
I hope it does start when I do it hahaha! So drivers door open electrics on and the stack unit does its wee mad thing then depress fully the throttle 5 times at least. Then electrics back off - then turn on and start engine and leave until full temperature. Then take it a hard drive somewhere?
Other than it has to be done by a virgin on a full moon thats it.
Cheers hope your suplying one of the female variety.Rich H wrote:Other than it has to be done by a virgin on a full moon thats it.
In Preston?
You'll be lucky!
You'll be lucky!
Certainly the population of bellshill which are virgins and over 16 is practically none
May I suggest returning the car to the chap you bought it from, asking for your money back, and leaving a small dog turd under the lining of the boot?
I don't think I've heard anyone have so many problems in their first month of ownership, except maybe Dezzy with his 111R, but that was more quality control stuff on a nearly new elise.
GregR wrote:May I suggest returning the car to the chap you bought it from, asking for your money back, and leaving a small dog turd under the lining of the boot?
Hhaha tell me about it. Just don't see how he could have knew about the problems in hand before selling it, think its just been bad luckGregR wrote:May I suggest returning the car to the chap you bought it from, asking for your money back, and leaving a small dog turd under the lining of the boot?
All good though its just wee niggly stuff still love the car
