Anyone technical.....
- Lazydonkey
Re: Anyone technical.....
Did someone on sellacock not have a plate that was like TADTS ?
That's the VX that has a plate. Rattles from the front end can only really be suspension, unless something major is falling off...s29ttc wrote:Just had a thought may be a stupid one but here it goes, see if you have just had it serviced you would have an oil change. I am sure someone said there is a cover on the bottom which they would have took off to get to the sump I take it. If so might just be one of the bolts loose and the cover rattling over bumps..........
Long shot.........
Ive just came back in after a 2 and haf hour run in the lakes (day off) i now have about 5 new rattles one of which sounds like it is coming from the foot well, but really comes from the brake pads. Ive also got the exhaust heat sheild, suspension and 2 unknowns, just keep the earplugs in!!
Will spend rest of day looking for them ready for my first trackday at the speedfair.
Rattles in the footwell, could be small stones or loose change.
Either that or the most likely/usual suspect brake pads rattling. Try a light dab on the brake pedal next time you hear the rattle.
