Koni shocks
Re: Koni shocks
Post by campbell » Fri May 23, 2008 9:54 pm
Also be aware that a minor change was made with Konis, involving a different setting for the spring platform particularly for the rears. This occurred when they changed from straight to barrel springs, as the rear mounting bracket was amended also.
Quite apart from ensuring which shock should be on which end (!) your mechanic mate should ensure that the circlip for the rears sets the spring platform to give the HIGHEST ride height poss if the shocks have straight springs.
It took me 2 years to work out why the rear of my car was slammed and the front "regular" after fitting a set of Tut's pre-owned Konis from the original N1 TUT! My car was much later and had the different brackets at the rear.
Sooner you get S2 Bilsteins the better of course. Bell and Colville been doing a stonking deal for under £500...
Matelotman
Re: Koni shocks
Post by Matelotman » Fri May 23, 2008 9:59 pm
campbell wrote: Bell and Colville been doing a stonking deal for under £500...
£617 inc VAT
Re: Koni shocks
Post by campbell » Fri May 23, 2008 10:06 pm
£617 inc VAT
offer ended then, clearly!
TAMBO
Re: Koni shocks
Post by TAMBO » Fri May 23, 2008 10:42 pm
NOOPS 160 wrote:Your welcome to my old set :thumbsup
that would be good if you could noops just need back ones...ill put mr tuts ones on the front for a couple of months as they are in good nick.
must say guys cheers for they help....
scrongefactor :oops:
Tambo
Re: Koni shocks
Post by GregR » Sat May 24, 2008 12:30 pm
I've also got a set if you need them. They're not exactly 'fresh' though ;)
