MMC brake discs and EBC Green Stuff *NOW WITH DISC PHOTOS*
Post by BiggestNizzy » Fri Oct 19, 2007 10:08 am
RICHARDHUMBLE wrote:Brake pads are only a couple of steps beyong getting the wheels off, as long as you put it all back together :thumbsup
  • Remove Wheel
  • remove 2 M10 Cap Screws and they are off (8mm Allen Key)
  • pop out old pads
  • push pistons back in
  • spray with copper slip (I like the stuff ina can from halfrauds)
  • put new pads in.
  • slide over disk
  • screw back on
  • wheel back on
Think thats about it
Post by Corranga » Fri Oct 19, 2007 5:32 pm
Ok, brake disc photos in my photobucket album (they are pretty large)
http://s13.photobucket.com/albums/a295/Corranga/brakes/
Can someone please advise whether i've screwed my discs or if I can simply buy MMC pads and fit them
*hides in fear*
DaveG
Post by DaveG » Fri Oct 19, 2007 7:08 pm
Anyone? Am I right in thinking that the MMC pads deposit a layer of material onto the disks which then acts as the friction surface (and stops the disk from wearing)? So looking at those pics, it only seems to be light surface wear and if so, maybe new MMC pads would restore the surface?
I may of course be talking bollocks! Someone will be along in a minute who knows what they're talking about.
I've changed the front pads on that car a couple of times, and believe me when I say its a doddle! 5-10 minutes each side. Be sure to use coppaslip tho as the squeal something chronic if you don't!
D
Sweet Zombie Jesus!
Post by simon » Fri Oct 19, 2007 7:39 pm
No idea whether the discs are screwed or not but if you want a hand changing the pads give me a shout, they're pretty easy though.
Stu160
Post by Stu160 » Fri Oct 19, 2007 9:36 pm
I would change to the correct pads and see how it goes,they dont look to bad.
Good luck
Stu
Stewart
Post by Stewart » Fri Oct 19, 2007 9:53 pm
I did wonder about giving them a very light sand (by hand) to remove any crud from the EBC's :?:
Stewart
Post by alicrozier » Sat Oct 20, 2007 7:30 am
BiggestNizzy wrote:
  • Remove Wheel
  • pop out old pads
  • put new pads in.
  • slide over disk
  • screw back on
  • wheel back on
Full instructions here: :)
http://www.elise-faq.info/index.php?title=Pad_change
Post by Rich H » Sat Oct 20, 2007 7:49 am
Discs look ok, but the only way of telling will be get proper pads in and thrash the tits off them. They will either recover or wear very quickly. I reckon you'll be fine but it will probably take a bit to scrub them back in.
Post by Corranga » Sat Oct 20, 2007 1:01 pm
cheers guys, i'm gonna attempt the fronts first as I still have the old pads, then when the rears arrive, hopefully i'll have a good clue as to what i'm doing :)
Fingers crossed the discs will be fine, time will tell I suppose.
Post by simon » Sat Oct 20, 2007 2:10 pm
Corranga wrote:cheers guys, i'm gonna attempt the fronts first as I still have the old pads, then when the rears arrive, hopefully i'll have a good clue as to what i'm doing :)
Fronts are completely different to the rears so it won't really help you doing that ;)
Post by Corranga » Sat Oct 27, 2007 5:15 pm
Done :)
Changing the pads over was really easy, although it took me a couple of hours as I was taking it slowly so as not to make a mistake. Winding back the pistons on the rears was a bit of a pain, but overall, the most problematic part was realising that i'd driven to my mums where the car was without the rear pads :oops:
Great to be out in the Lotus again though following much Audi driving...
YvoTuk
Post by YvoTuk » Tue Oct 30, 2007 3:21 pm
Sorry to jump in a little late, but if still possible, I'd throroughly clean the discs with brake cleaner or similar before trying the MMC pads.
That will at least help to get any deposits away.
From there, it's fingers crossed and test if they still work :)
