Newbie from Aberdeen looking to get in to a lotus.
Come and introduce yourself
Callummarshall
Post by Callummarshall » Mon Oct 06, 2014 9:21 pm
Hi all,
I'm Callum and I'm looking at buying a elise/exige as an occasion car, I joined up to seloc looking for advice and was recommended to sign up here. I was looking for advice regarding running costs, servicing and which model/spec is considered to be better for a start in the chassis, I have an upper limit of £20,000.
Is there anywhere up here reputable for servicing/care?
I was budgeting £2500 or so a year to run it but have been told this is a bit on the high side.
Thanks
Callum
Re: Newbie from Aberdeen looking to get in to a lotus.
Post by Mikie711 » Mon Oct 06, 2014 9:51 pm
It is if nothing breaks :)
And welcome to SE.
A few good garages up here, Ricky Gauld, John at JD's in Insch but most put there cars down to Murray's in Edinburgh. Check out the thanks to murrays thread here.
You'll need to drive a few to find out what you like Elise in rover or toyota engines, or early S2 Exige possibly a S if you look and haggle hard enough for your budget.
mxvx
Post by mxvx » Mon Oct 06, 2014 10:08 pm
Welcome Callum
I cannot comment on the costs as I have not had my car long enough but that seems high side (depending on the car)! You will need to try out a few to see what suits you.
Post by mwmackenzie » Mon Oct 06, 2014 10:40 pm
:welcome
C7Steve
Post by C7Steve » Tue Oct 07, 2014 12:00 am
:welcome
Steve.
Danny T30TUS
Post by Danny T30TUS » Tue Oct 07, 2014 4:42 pm
Hey Callum, I am also newish to thus Forum and live in Aberdeen. I bought K series S2 earlier this year. More than happy for you to have a look and come for a run in it if you want. Happy shopping whatever the outcome.
Danny
flyingscot68
Post by flyingscot68 » Tue Oct 07, 2014 5:16 pm
:welcome
Post by robin » Tue Oct 07, 2014 6:11 pm
20K is loads if you're looking S1 or non-super charged S2 in either Rover or Toyota form. Do you have plans to use on track, or will it be a road car; if a road car, will it be mostly for fun or will you need to commute in it also?
Post by tut » Tue Oct 07, 2014 6:28 pm
Mike's ex car is coming up for sale.
Post by renmure » Tue Oct 07, 2014 6:31 pm
:welcome
I do think that a budget of £2500 / for running costs is more than generous.
Post by j2 lot » Tue Oct 07, 2014 6:45 pm
:welcome
Your purchase budget should give you a decent straight car and if you buy wisely your running costs should be well within your annual budget too.
As for servicing - MMC, Lotus dealer for Scotland is probably your best option. Happy hunting.
highlander
Post by highlander » Tue Oct 07, 2014 9:04 pm
tut wrote:Mike's ex car is coming up for sale.
It sure is,not sure if it's "my 1st Lotus" but most certainly a very good car.....7000 miles covered since a comprehensive rebuild.
Will be comfortably under £20K,ask if you want more details but the whole rebuild thread is on here.
Welcome to SE :thumbsup
Post by tut » Tue Oct 07, 2014 9:10 pm
You will not get a better one.
Mike is a bit of a perfectionist, and Jim would tell you if it was wanting for anything.
Post by j2 lot » Tue Oct 07, 2014 9:25 pm
highlander
Post by highlander » Tue Oct 07, 2014 10:02 pm
tut wrote:You will not get a better one.
Car is at MMC at the moment,windscreen being replaced as it has a crack behind the rear view mirror and ECU is possibly going back to Lotus for a "re-boot".......something on the map is causing an erratic idle speed so best option is wipe clean and reload so nothing to corrupt the settings.
Apart from the enevitable stone-chips,the car is good to go......and it certainly goes!!
Another happy customer here of MMC,servicing & sales always carried out very professionally.Don't usually use main dealers but they are the exception...recommended.
