Much in need of advice as whether the landscaper whos just finished my garden is having a laugh or has done a genuine job
He'd laid Bradstone Old Riven slabs in a 40 square metre area. Problem (as I see it) is it ain't level, in that from one slab to the next there's up to a 10mm drop/rise. It looks feckin horrendous, especially the bit I can see through the patio doors when I'm sitting on the sofa
When I questioned him orginally he's said it because the slabs are varying thicknesses. I've checked with Bradstone and the maximum difference in thickness (between thinest and thickest) is 6mm. He's also laid it on a base of sharp sand and cement rather than wet mortar which I always assumed should be used with varying thickness slabs so you still end up with a flat, level surface.
Am i talking mince or is he running a bath
Any advice on this greatly appreciated as Lorna is giving me a really hard time about this
cheers
craig
P.S. AndyG - won't be forwarding on this guys details to you afterall
