by Rich H » Thu May 17, 2007 10:28 pm
Grinning again!
After defecting to the Porky side for a couple of weeks the pig is currently awaiting a dizzy (Arriving tomorrow) so the Liz got a run today for the first time in 2 weeks.
I now appreciate the Elise so much more! The shift is short and accurate, the steering is light and agile, the clutch works (!), all the electrics work, I have power and torque again and I can overtake things!
thinfourth
by thinfourth » Thu May 17, 2007 11:01 pm
It doesn't have any electrics rich
Thats why they all work
by Rich H » Fri May 18, 2007 8:02 am
It has washer jet that work
It also has a roof that comes off
And an engine that will do 6k rpm without sounding like I'm killing it (too much)
thinfourth
by thinfourth » Fri May 18, 2007 8:15 am
For sounds of it the roof of the porker would come off too if you could get it to go fast enough
by Rich H » Fri May 18, 2007 8:38 am
Nah, the shell is solid, it's the bits bolted to it that are the problem.
This weekends job is to drill and tap and new fill/level and drain plug hole in the transmission... The plug was nearly round when I got it. Now it's totally round
I didn't even bodge it I got a proper 17mm allen key and everything.
I even have permission to work on the car form SWMBO, as she wants to take a load of crap to the tip in it. It's the most practical option out of Liz, MX-5 and Porka!
