SD Memory Cards
johnboy_78
SD Memory Cards
Post by johnboy_78 » Tue May 15, 2007 2:25 pm
How do you know which one to opt for :?: :shock:
My wife bought me a Oregon ATC2K camera for my birthday, which I'm looking forward to playing with, but she didn't get me a memory card to go with it. I plan to pick up a couple of 2Gb SD cards which should give me 2hrs viewing time.
However, when searching the net for places to buy said cards, the choice is massive and it's not clear why some 2Gb cards are £10 and other apparently similar cards are £50. What should I be looking for in an SD card for a vidoe camera? For example, is £21 a good price for a SanDisk Extreme III card?
Sorry for all the questions, but I'm totally clueless when it comes to this sort of thing :roll:
Thanks,
John
2001 Europa Blue VX220 2.2 - SOLD
2004 Alpina Roadster S 3.4 - SELLING.... :-(
Post by Sanjøy » Tue May 15, 2007 2:30 pm
Speed of read / write for the application, I bought a "fast" 2GB for my Nokia as read slow cheap Sd cards made tomtom drag.
Post by tut » Tue May 15, 2007 2:46 pm
Sanjoy
No prob with my TomTom with hard drive.
<BG>
ps Could you please update your tt entry as it is out of date, and if you happen to find your cheque book and a pen............
Blaque
Post by Blaque » Tue May 15, 2007 2:52 pm
Post by robin » Tue May 15, 2007 5:27 pm
If you plan on using it as a video recorder then you need to work out what the data transfer rate is. TBH, even the quickest MP4 video bit rate is likely to be no problem for the slowest modern 2GB card.
Just make sure that if your device is SD (largest legal capacity 2GB, largest non-standard capacity 4GB) you don't buy SD HC (smallest capacity 2GB, largest capacity more like 4TB) and vice-versa.
Gazbo
Post by Gazbo » Tue May 15, 2007 5:47 pm
'Climb aboard the shopping trolley of chaos'.
Post by DDtB » Tue May 15, 2007 6:13 pm
Gazbo wrote:http://www.ebuyer.com
Very cheap!
:D
True... have used them a couple of times.... but they don't get the best reviews on the web....
I won't be using them again either after the last encounter I had with them...
:roll:
tigger2
Post by tigger2 » Tue May 15, 2007 6:18 pm
i just bought myself a 2gb Lexar Professional 133x speed from ebay for £23.90 including postage. you can find some bargins on ebay sometimes :)
delands
Post by delands » Tue May 15, 2007 9:08 pm
DEL
2022 Hyundia i10 N-Line
2019 DS3 Crossback
johnboy_78
Post by johnboy_78 » Wed May 16, 2007 9:18 am
robin wrote:If you plan on using it as a video recorder then you need to work out what the data transfer rate is. TBH, even the quickest MP4 video bit rate is likely to be no problem for the slowest modern 2GB card.
The camera on its highest quality setting is 640x480 pixels (VGA) at 30 frames per second (not sure if that's the sort of info you were looking for?). It also says in the manual that the recommended card is a SanDisk Ultra II SD card. Given that's the case, is there any benefit in going for the Extreme III card overs the Ultra II? I realise that the Extreme has a quicker read/write speed, but will i notice any difference?
THanks to everyone for the helpful links, I'll have a look at them tonight :thumbsup
dr al
Post by dr al » Wed May 16, 2007 5:06 pm
Very cheap!
:D
Yep - i've used them loads of times - no problems - and VERY cheap!
A.
Post by Rich H » Wed May 16, 2007 6:05 pm
I'm pretty sure I can get 40% off any carphonewarehouse stuff, they sell the sandisk cards. dunno if these are any good.
