fuel
scott_e
fuel
Post by scott_e » Thu Apr 26, 2007 12:37 pm
what do you use ?
i was recommended to use super unleaded every 3 or 4 tanks.
supermarket fuel ok ?
optimax ?
thanks for advice.
Scott
Post by ed » Thu Apr 26, 2007 12:41 pm
In my exige i used to run standard fuel for everything apart from track work. Your car has a knock sensor and can tell the difference. I never used supermarket fuel but some do. HTH cheers Ed
k12chu
Post by k12chu » Thu Apr 26, 2007 12:46 pm
i use shell v power. quite happy with it. :D
thinfourth
Post by thinfourth » Thu Apr 26, 2007 12:51 pm
Asda own brand veg oil :thumbsup
Post by ExigeKen » Thu Apr 26, 2007 2:38 pm
Scott,
I use BP unleaded fuel mainly because it is the only garage where I live and has run great over the past two years. I am not keen on supermarket fuel due to problems with a previous car but I guess it depends who supplies the supermarket. I occaisionally fill with super unleaded not sure if it really makes a massive difference. HTH.
Cheers, Ken.
jamie
Post by jamie » Thu Apr 26, 2007 2:58 pm
There has been a load of reports on different fuels providing performance advantages and on the Yota powered car their is a knock sensor so it could be worth it. Big gains will only be had on cars with FI eg Scubies have seen 20hp gain on a super!
To really make the most of it you would need a more agressive map.
Def worth it for track work though. On my Bemani Exige I had to use Super or i would have had issues as the Map was designed for it.
Post by Rich H » Thu Apr 26, 2007 3:18 pm
Petrol.
Fill up when stack says refill.
Anywhere that sells it, if there is a choice then the cheapest.
HTH
/Tatty S1 faction!
Post by campbell » Thu Apr 26, 2007 7:35 pm
I am a BP Ultimate convert. Primarily for the Nectar points, but they themselves make the car feel like a 2.0 when it's just a 1.8 ;-)
lutonpilot
Post by lutonpilot » Thu Apr 26, 2007 8:41 pm
Tescos 99 is by far the best gives extra power and works great in my aeroplane too! Its a minimum of 99 octane infact is usually 101 octane puts it up with 100LL Avgas without the lead! Trying to find the link to a test I read about it and the power curves using everything including V-max BP ultimate etc on rolling road! Found it! http://www.thorneymotorsport.co.uk/tuni ... ults.shtml
Id rather be flying!
S1 Elise 111s
Avid Speedwing
VXJON
An Equal Opportunities Lover
Post by VXJON » Thu Apr 26, 2007 10:48 pm
Tesco 99 :D
VXJON
Post by VXJON » Thu Apr 26, 2007 11:08 pm
NOOPS 160 wrote:
VXJON wrote:Tesco 99 :D
Yes but your captain slow :lol:
Every little helps :finger
Post by dezzy » Thu Apr 26, 2007 11:36 pm
Was told by salesman at Glasgow MMC who sold me the car that normal unleaded was fine, but someone on here told me about the knock sensor stuff in the Toyota engine and so switched to Shell V-Power. Not really sure how much of a different it makes, but I'm definitely a petrol snob and never used supermarket petrol unless forced to due to location or whatever. The v-power petrol is also meant to have all that cleaning stuff in it that's supposed to be good for the engine, so that's another bonus of using it I guess.
Plus, I'm building up points with my shell pluspoints card! :D
k12chu
Post by k12chu » Fri Apr 27, 2007 12:48 am
campbell wrote:I am a BP Ultimate convert. Primarily for the Nectar points, but they themselves make the car feel like a 2.0 when it's just a 1.8 ;-)
i used to fill BP for the nectar points. i tried shell v power for a change and... and now am stuck with it. i felt a good amount of difference. and oh... get the shell plus point card. :D
PhilA
Post by PhilA » Fri Apr 27, 2007 11:11 am
yota engine is mapped to 98 ron - Nick Adams, 111R development leader.
the knock sensor allows it to run fine on normal unleaded.
id never used supermarket fuel - its inconsistant at best.
i used shell optimax - ran without any problems.
if i remember correctly, the shell stuff worked best with scoobies - less knock compared to bp ultimate.
so shell optimax for best performance, cleaning, lubrication and mpg.
Phil
Ford Focus Sport
Post by rossybee » Fri Apr 27, 2007 11:37 pm
Bollocks to the supermarché snobbery, chaps - I fill both beasts in the cheapo places, never had any trub :wink:
RS6 = 95 or 98 RON,
Snot = 97+RON :D
Elise no more :roll:
'72 Alfa Romeo Giulia Super
'07 Aston Martin Vantage
:blackeye
