A built in hair drier!
It moves 240cfm! Wow! An Audi turbo moves 400cfm so it provides half the gains of a real turbo! And it only draws 2.2 amps!*
*This product will move 240 cfm at atmospheric pressure only, an Audi turbo will give 400cfm at around 10psi, this is not a like for like comparison and should not be bought on the premise that it will do anything apart from fall apart , drain your battery when it draws 20 amps under load and embarrass you in front of your mates. This does not affect your statutory rights as you don't have any.
For the elise that has everything...
- thinfourth
