radiator replacement
k12chu
Post by k12chu » Wed Apr 18, 2007 2:16 pm
need to replace the radiator for the S2 (under warranty). if i pay additional £100 they (Murray Motors) said they can source the upgrade (aluminium type). should i upgrade for that price?
or am i being taken for a good hand break turn? :?
Post by ed » Wed Apr 18, 2007 2:21 pm
I guess it depends which one they are putting in. The standard ali one is around £85 more on eliseparts and the other is aound £200! cheers Ed
http://www.eliseparts.com/shop/index.ph ... 4144519f41
Post by Stephen » Wed Apr 18, 2007 2:21 pm
I would go for the upgrade but make sure that they provide a warranty for it.
Post by Rich H » Wed Apr 18, 2007 2:21 pm
As long as it is a proper fully ali one then yes take them up on it. Reports suggest a lower running temp, it'll take a higher pressure and it will last longer :thumbsup
Post by Rich H » Wed Apr 18, 2007 2:23 pm
Survey says yes :wink:
Post by ed » Wed Apr 18, 2007 2:41 pm
:withstupid :thumbsup
james
Re: radiator replacement
Post by james » Wed Apr 18, 2007 4:17 pm
k12chu wrote:need to replace the radiator for the S2 (under warranty). if i pay additional £100 they (Murray Motors) said they can source the upgrade (aluminium type). should i upgrade for that price?
Just got mine done at the weekend there at JPS under warranty that came with the car when purchased at MMC. Dan replaced it for the all alloy one.
Temperature runs at exactly the same as before (85 deg cruising) but the heater now works better (hotter air.)
PM me regards the "upgrade costs."
bertieduff
Post by bertieduff » Wed Apr 18, 2007 4:28 pm
If my sums are correct it's about £70 dearer than standard.
So they're charging £30 to source it.
I just sourced one in 30 seconds.
So that means they're charging @ £3600 per hour. :shock:
I feel a career change coming up :D
