by tut » Tue Mar 06, 2007 11:55 pm
Ken
The Bell 47G, also known as the Sioux, was the first real Military helicopter, just a two seater with a T/C piston engine. If you could fly that you could fly anything, as like the Elise, it was just bare essentials.
No computerised controls, not even hydraulics, so apart from the usual antics of a cyclic column, collective lever, and tail rotor pedals, you had a manual twist grip throttle, and the rpm had to stay almost constant. So every time that you raised the collective lever with the left hand, you had to control height and speed with the cyclic stick with the right hand, directional control with left or right feet on the pedals, and also rpm with the left hand. They would have probably found a use for your cock as well given more time.
Net result was that during training you needed a football field to try and hover in.
Once operational, and in a War situation, you could be flying flat out at 10', trying to navigate or map read, using three different radios at the same time, UHF, VHF, HF, to the Artillery, FGA's, and ground troops, whilst crapping yourself when some slant eyed git tried to spoil your day with an AK47 or SAM 7.
Of course, now I am not considered capable of using a mobile phone when I am driving.
We flew without doors on in the Far East, had this big plastic bubble, so it was as close to real flying as you could get. No probs at speed, but trying to get out of a jungle clearing in Borneo vertically after picking up a CASEVAC, 40 deg temp, and 100ft trees, was a laugh a minute. Really could have done with a S/C Honda engine conversion then.
That together with flying its later big brother, the Bell 205(Huey) in the Oman war for seven years was as good as it gets. Got to fly many more types at ETPS (Empire Test Pilots School), and then in civilian flying, but it never matched those times.
Just found this on Google. He may have gone to the moon, but he was not so hot in a 47G.................
NASA had a number of Bell 47s during the Apollo programme, used by astronauts as a trainer for the Lunar Lander. Eugene Cernan had a near disastrous accident shortly before his flight to the moon on Apollo 17 by crashing one into the Indian River.
