New Tyres
k12chu
New Tyres
Post by k12chu » Wed Feb 14, 2007 12:29 am
now that i have managed to replace the damaged alloy wheel, its time to buy a new front left tyre. am currently running on standard (bridgestone) tyres. was thinking of replacing all 4 tyres. was actually thinking of upsizing the tyre.
what would be the ideal replacement for bridgestone potenza? am not looking at a dedicated track oriented tyre as i'll be using the elise as my daily mode of transport. at the same time, i'd prefer something which will give some decent performance on the track as well.
also like to know how much it would cost me and where i can pick up a set from.
thinfourth
Post by thinfourth » Wed Feb 14, 2007 9:23 am
Well first of you are bringing the car round to mine tonight to see if there is any other damage, unless uldis has already cast his eye over it.
Post by Gareth » Wed Feb 14, 2007 9:27 am
thinfourth wrote:Well first of you are bringing the car round to mine tonight to see if there is any other damage, unless uldis has already cast his eye over it.
"I await the slaggin"
thinfourth
Post by thinfourth » Wed Feb 14, 2007 9:58 am
It will be a long wait
I've been an hands on engineer/mechanic for years i have better eye then you will also i have a clock gauge to check for runout.
i am sure you are way better at graphic design then i ever will be
Post by GregR » Wed Feb 14, 2007 11:50 am
IIRC - these are a good bet on the S2 :) :-
http://www.tirerack.com/tires/tires.jsp ... Neova+AD07
MMC ought to be able to get you a set, with the 10% S_E discount ;)
Uldis
Post by Uldis » Wed Feb 14, 2007 12:01 pm
I'll check it out tonight.
Post by Gareth » Wed Feb 14, 2007 12:20 pm
The wheel was totally buckled.
No obvious unusual movement in the hub.
Disc spun round like it should without any noticeable friction.
Only conern is the brake caliper took a whack especially from the drive home caused by the spoke of the wheel.
k12chu
Post by k12chu » Wed Feb 14, 2007 1:54 pm
if only i could drive the car :?
with the current setup i just could shave the whole brake caliper by the time i drive to ur place. shall fix the new wheel and see how different things r.
k12chu
Post by k12chu » Wed Feb 14, 2007 1:57 pm
shall see u this evening. hope u havent forgotten the jack n toolkit
k12chu
Post by k12chu » Wed Feb 14, 2007 1:58 pm
Gareth wrote:The wheel was totally buckled.
wanna drop in as well this evenin?
Post by Gareth » Wed Feb 14, 2007 2:31 pm
Sorry, tied up this evening :D
thinfourth
Post by thinfourth » Wed Feb 14, 2007 2:57 pm
I'll bring my clock what time?
Post by jj » Wed Feb 14, 2007 3:17 pm
Gareth wrote: Sorry, tied up this evening :D
Alllllright. You or her? :lol:
Uldis
Post by Uldis » Wed Feb 14, 2007 3:54 pm
thinfourth wrote:I'll bring my clock what time?
7:15 pm
k12chu
Post by k12chu » Wed Feb 14, 2007 4:01 pm
OK. see u all at 7:15. staying over for dinner? or a pizza?
