Its winter, anti corrosion stuffffff
Post by Sanjøy » Wed Feb 07, 2007 3:05 pm
Take nfrom an old bikers mailing list I am on. Boys were raving about this. Anyone come across it before, sticky enough to put on wishbones to prevent them looking like crud ?
http://www.brmc.co.uk/ACF-50%20ANTI%20CORROSION.htm
SP
Dicey
Post by Dicey » Wed Feb 07, 2007 4:17 pm
Sounds fab doesn't it. I ordered a tin yesterday from M and P. Will let you know how I get on...
Mike.
Michael
Post by Michael » Wed Feb 07, 2007 5:49 pm
wonder if its chemically similar to kurust
S2 Exige - sold
Boggo 911 (997)
Scottd
Post by Scottd » Fri Feb 09, 2007 2:37 am
Might get this, but never keen on sprays cause half of it normally goes where you don't want it... but the tub doesn't say how much is in it :? - £8.95 CORROSION BLOCK GREASE TUB
S1 50th Ann.
Post by tut » Fri Feb 09, 2007 10:03 am
Cowan had ordered the complete Cat B/Procedure B, floor corrosion kit from Lotus, nearly £300 worth, as it is only done for free within the 8 year corrosion warranty.
He had already taken up the black mat and cleaned the floor, and it does not look too bad, just discolouration, so the simpler A kit would probably have done. It has a lot of cleaner/degreaser/primer/adhesive bottles in it, including the ACF 50 solution.
It also has two new breathable carpets, but most important for me, two smooth aluminium floor plates, and you know I love ali. Bit too much bending in the footwell for me, so will get my son to fit it.
