Shug / Andy G / camcorder advice......
Post by rossybee » Mon Dec 18, 2006 3:05 pm
Have just posted this on blatchat, would appreciate any views from some of you more technology-wise dudes on here :wink:
http://www.blatchat.com/t.asp?Id=121529
Shug - I know you raved about the Archos 504 but truthfully, is it a good choice for kids birthdays / Xmas / holidays / general family use, over and above slapping it on ma lid & whacking about the roads in Tayside? :?
2004 Bentley Conti GT
Post by rossybee » Mon Dec 18, 2006 8:01 pm
This request isn't limited to the two amp3 chaps tho' :D
Any advice welcomed - the Sony DCR-HC24E seems to get rave reviews from the budget end of the market :wink:
~ ~ Cal ~ ~
Post by ~ ~ Cal ~ ~ » Mon Dec 18, 2006 8:10 pm
Hi there,
I have a TRV 22E
It has fire wire, DV out ( only) but it is an exceptional performer. Cost me £450 a few years ago but has given me confidence to buy Sony again
No need for bullet cams - I mounted this on the outside of the door round KH using a B-Hague mount with no issues. I ran an external mic into the cabin.
Hope this helps - ideally you want DV in so that you can edit stuff on your PC and then send it back to the camera
Cal
Das Über Barge - Volvo XC90 ( 3 kids spec)
Bachelor Spec - Mk6 GTi (Manual)
~ ~ Cal ~ ~
Post by ~ ~ Cal ~ ~ » Mon Dec 18, 2006 8:16 pm
More info on many cameras on this site
http://www.camcorderinfo.com/content/so ... review.htm
Regards
Cal
Post by Sanjøy » Mon Dec 18, 2006 9:12 pm
~ ~ Cal ~ ~ wrote:Hi there,
Surely DV out ?
I have used the older model you have there and am also looking to pick up a new cam with DV out and analog in for bullet / helemet cam.
Planning to group cycling trip again this year and being the techy in the group the boys are after some shots from helmet as I generally bring up the rear of the peleton.
~ ~ Cal ~ ~
Post by ~ ~ Cal ~ ~ » Mon Dec 18, 2006 11:56 pm
Ideally DV in AND out ........
Therefore allows you to firewire the signal to your PC and be able to send it back to the camera after editing. The TRv 22 E does not have DV in :cry:
I cut most movies to DVD regardless so it doesn't make much difference for me..
CGS
Post by Andy G » Tue Dec 19, 2006 12:34 am
HI Ross
I've used an Archos Av500 for quite a while and its been genial for the track as the camera attatchment is bullet cam style.
You can simply drag anddrop the films on and off the player making it easy to upload them online.
Shug's got a demo onein the shopin glasgow ifyour heading through that way any time soon??
jason
Post by jason » Tue Dec 19, 2006 1:18 am
Does a bullet cam not require DV in?
Skyenet
Post by Skyenet » Tue Dec 19, 2006 1:38 am
jasonliddell wrote:Does a bullet cam not require DV in?
Bullet Cameras normally have analog video output (phono or BNC connections). You can only record footage from a Bullet Camera with analog Video out onto a Camcorder, Video Recorder, DVD Recorder or Archos if these recording devices have analog Video in. Most DV Camcorders have DV Out as this is used for outputting video to PC editing software via a Firewire cable and card or to a DVD recorders. DV In is not just as common but means that the Camcorder can accept video footage from another Digital Video device's DV output via a DV firewire cable.
My Camcorder had DV Out, DV In, Analog Video Out and Analog Video In. This means that for example I can send footage to another DV camcorder (via DV Out) or to a TV (via Analog Out) and record footage from another DV Camcorder (via DV In) or from a Bullet Camera (via Analog Video In)
Post by Sanjøy » Tue Dec 19, 2006 10:21 am
And the make model is ... ?
Post by Shug » Tue Dec 19, 2006 11:44 am
The great advantage of the 404 (or 504/604) with the bullet cam is that you don't have to re-encode the video for web use or to drop it onto the PC. Even with the firewire option on a DV camcorder, you will still have to drop your footage into the PC in real time for editing. The Archos players simply connect with USB2.0 and you drag the file across.
As a dedicated camcorder, there are better than the *04 range, that's not it's main purpose: they are media players, and really, the best on the market. The bullet cam is a really high quality add-on though, and really extends the use of the player.
From the POV of a family gadget - well, firstly, you can throw away the wee DVD player for the car. A 30GB player will store 85 full length movies. You can also (with a wee FM transmitter) use it as a jukebox for the car (~15000 songs). You can even (with the travel dock) use it as a portable storage device for holiday snaps (300000 photos, you can download your stills cam into it) I've not even gone into the DVR station you can buy, to let you record from any video source (digibox, DVD player, anything with a composite output or a scart)
There's a lot of stuff you can do with the Archos kit - best thing is that they now have a user interface that lets you do everything you want, without giving you brain-ache. Great products :thumbsup
Post by Shug » Tue Dec 19, 2006 11:54 am
You still coming though this week? I've got everything in stock 8)
BigD
Post by BigD » Tue Dec 19, 2006 12:52 pm
I have the bullet cam from this site http://www.dogcamsport.co.uk/?kw=helmet ... QgodnHkoUQ
I also bought a Cannon DV camera with, as Cal said, DV in. The cam itself has been excellent and has been on the wing of my car doing about 160 ish on the Autobhan in Germany and didn't fall off. I bought it so that I could put it on my helmet on the bike too. I will probably end up buying a suction mount at some point as the bullet is not so good when it rains.
From memory the whole lot only cost about £450. :D
The good thging about having the Camcorder as well means that you can use it on it's own when you want to. :D
Here's the footage from the Isle of Man TT circuit with it. http://video.google.co.uk/videoplay?doc ... 9&hl=en-GB
Post by simon » Tue Dec 19, 2006 2:34 pm
Post by Sanjøy » Sun Jan 14, 2007 10:51 pm
Looking for some more advice chaps.
Sarah bought me a Sony DVD camcorder for Xmas. Only problem is that its ount output is to mini DVD and component
http://uk.insight.com/apps/productprese ... 5&src=FRO1
Spoke to John Lewis and they are happy to take it back even though it is after the 28 days.
The currently have the following in their clearence for less than the one I got.
http://www.amazon.co.uk/Sony-DCR-PC55E- ... B0007WG3SE
Thoughts ? Anyone done any more research on Cams in the £300 price bracket or have something they can reccomend ?
SP
