Aquarius engine.
Aquarius engine.
Post by tut » Tue Nov 22, 2016 1:04 pm
Just saw an article about it on CNN.
What do you reckon to its potential Simon?
http://www.al-monitor.com/pulse/afp/201 ... nment.html
Re: Aquarius engine.
Post by Corranga » Tue Nov 22, 2016 1:48 pm
Not read the article, but in theory, if they have a cheap to make, reliable, super efficient petrol engine, they are in.
All electric technology isn't quite there - and although it might well be closer than most want to think, the infrastructure isn't there for charging them, nor for supplying the charge - a coal fired power station charging electric cars is pointless right?
Petrol cars aren't going to be replaced overnight. The majority of folk can't afford a new car, never mind a hugely inflated price electric one. You only have to look at the popularity of small petrol cars in the UK to see this would work for some years to come imo..
Post by BiggestNizzy » Tue Nov 22, 2016 1:52 pm
Looks like wind and pish to me.
Scuffers
Post by Scuffers » Tue Nov 22, 2016 5:56 pm
tut wrote:Just saw an article about it on CNN.
well, yes and no.
none of this is new, there's a NZ company that did this years ago, made a replacement for a Subaru flat 4 using paired linear pistons - the theory is that you don't have the same skirt friction losses as there is no side load on the piston(s), the downside is you still have to have a slide block or the like to get to the crank (looking at the pictures in that article it looks like how ship engines are built with vertical pistons onto a cross-block and con-rod).
Put simply, it's a non-starter, fine for stationary/BIG stuff, no use in a small package.
if you into this kind of this, the most promising is an Axial engine from Duke:
Watch on YouTube
thinfourth
Post by thinfourth » Tue Nov 22, 2016 7:24 pm
As above
You have a big mass wobbling back and forth so it will vibrate like a barsteward
And i don't know about you but the wheels on my car go round and round not back and forth so you will need a crank to eat up some power
The max theoretical efficiency of an internal combustion engine is about 50%
Current cars are reaching 30% ish
The best engines in the world are low speed super long stroke marine diesels which are reaching 53% with some deeply clever tech on them including using a power turbine from exhaust gases feeding into the crankshaft and exhaust gas heat recovery to run a steam turbine
So double is 60%
It ain't happening
Also
Once you have driven an EV it makes an internal combustion engine seem like something out of the victorian age
Sorry the internal combustion engine has reached its peak
While i love a ICE in some places i would prefer my daily driver to be electric
pete
Vexatious Litigant
Post by pete » Tue Nov 22, 2016 8:23 pm
You wrote this in an earlier post ages ago, I think you'd driven a Leaf?
Anyway, I read it, booked a test drive off the back of it and we get an i3 next month.
You're right.
(Sometimes that's just nice to hear).
Sent from my MotoG3 using Tapatalk
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
Scuffers
Post by Scuffers » Tue Nov 22, 2016 10:45 pm
thinfourth wrote:Once you have driven an EV it makes an internal combustion engine seem like something out of the victorian age
to a point, you're right, the issues are still with energy storage, although the goalposts are moving fast.
ICE's will always have a place, just not sure it's going to be in everyday cars for much longer.
whilst we are talking wacky engines, my personal favorite is this:
https://en.wikipedia.org/wiki/File:Napi ... mation.gif
(gurrr... board does not seem to supports .gif's)
The Napier Deltic
thinfourth
Post by thinfourth » Wed Nov 23, 2016 7:16 am
You're right.
Yep test drove a leaf and was amazed at home it drove
I then got a new job which involves zero stop start traffic and ten miles less a day so i can't justify one yet
And the attraction is zero to do with the tree huggery element it is purely how it drives
kerryxeg
Post by kerryxeg » Wed Nov 23, 2016 7:47 am
I didn't spend long on the article, but the Simons diagram looks similar to a cranked piston fuel pump, but obviously in reverse. The piston pump drive was applied at an angle so the pistons saw full travel as the drive head rotated. I suppose you could design an engine with the reverse of the principle. The piston pump I saw was from an aircraft, it was a pretty old design in the 80's and had been replaced by a gear pump design.
Scuffers
Post by Scuffers » Wed Nov 23, 2016 9:23 am
thinfourth wrote: Yep test drove a leaf and was amazed at home it drove
if you think the leaf drives nice, god knows what you would make of a Tesla S!
it's the first EV I have driven that is a proper full sized car and put bluntly, exceeds everything else in that size/shape.
thinfourth
Post by thinfourth » Thu Nov 24, 2016 8:11 am
If i struggle to justify the expense of a leaf
Do you think i am going to be buying a tesla? :damnfunny
rawsco
Post by rawsco » Thu Nov 24, 2016 5:29 pm
Man maths applied to Tesla, not to leaf
Rawsco
2021 - Tesla M3LR
2019 - Exige 410
graeme
Post by graeme » Thu Nov 24, 2016 6:07 pm
I think EVs will see a surge in populartity once they are affordable AND desirable. It's one or the other at the moment. The number of Model 3 deposits taken suggests there's room for some competition in between a Zoe/Leaf/i3 :puke and a Model S :love
211
958
Scuffers
Post by Scuffers » Thu Nov 24, 2016 6:54 pm
graeme wrote:I think EVs will see a surge in populartity once they are affordable AND desirable. It's one or the other at the moment. The number of Model 3 deposits taken suggests there's room for some competition in between a Zoe/Leaf/i3 :puke and a Model S :love
exactly,
and if you add in the fuel costs it starts to stack up.
based on 10,000 miles PA (a low figure) you're looking at £100/month saving in fuel costs to run a model S vs. petrol car.
Yes, the model S is a £50K+ car, but the 3 won't be....
rawsco
Post by rawsco » Thu Nov 24, 2016 7:57 pm
I configed up a p100d for a laugh with all the options... 136 grand!
Rawsco
2021 - Tesla M3LR
2019 - Exige 410
