5th gear, long legs.
captain
Post by captain » Wed Aug 26, 2015 8:02 pm
Got my first Elise today (thanks to RichieK for a good deal and being an all-round decent chap)
Driving home tonight I selected 5th for the first time. Bugger. Nowhere for my knee to go. I'm 6'4" and fit perfectly fine - except for the gearknob setting up camp in the very spot where my left knee lives. Now, the majority of my commute is on wee b-roads so I'm not using 5th but is there an easy solution to this? Don't really want to shorten the shaft but possibly a wheel spacer?
Driven a few Elises in the past, both s1 and s2 and never noticed this but I probably never tried top gear. I had a vx220 years back which wasn't a problem.
Dave
Re: 5th gear, long legs.
Post by Dave » Wed Aug 26, 2015 8:14 pm
I'm not sure which variant you've got, but when I had my S1 Exige I moved the position of the foot rest and it gave my knee a bit more room, had to drill the rivits out that held it in place and then it was just a case of re-drilling and riveting it back in place.
captain
Post by captain » Wed Aug 26, 2015 8:25 pm
Ahh that's interesting, cheers.
It's an s1 I got, love it :)
BigD
Post by BigD » Wed Aug 26, 2015 8:43 pm
I bought a spacer for the steering wheel which is 40mm so spaces the standard wheel out and leaves more room for the knees. Makes a good difference. Think it was from Elise shop.
Post by tut » Wed Aug 26, 2015 9:31 pm
i have the same problem so just shortened the gear lever.
Post by Corranga » Thu Aug 27, 2015 8:02 am
My S1 has a short shifter kit (shortened gear stick) in it and my brother in law has the same issue as you do with that so it won't necessarily help you, though he is a bit taller at 6ft9.
captain
Post by captain » Thu Aug 27, 2015 8:58 am
Jesus H. 6'9", I assume he needs the roof off?
Thanks chaps, I think if I remove the footrest completely I can rest my foot against the bulkhead which ought to help.
Post by Dominic » Thu Aug 27, 2015 9:30 am
BigD wrote:I bought a spacer for the steering wheel which is 40mm so spaces the standard wheel out and leaves more room for the knees. Makes a good difference. Think it was from Elise shop.
Think I could be tempted to fit one of these - works nicely in your car Donald.
BigD
Post by BigD » Thu Aug 27, 2015 9:31 am
captain wrote:Jesus H. 6'9", I assume he needs the roof off?
My problem was mainly with the other leg as my hand would get caught between the wheel and my leg when turning, the wheel spacer helped that a lot. 8)
mxvx
Post by mxvx » Thu Aug 27, 2015 10:05 am
Is it a blue s1?
Post by Shug » Thu Aug 27, 2015 10:07 am
Some short shifters also give you the option of moving around the lever positioning. The actual lever has a dogleg back into the cockpit, on some, you can rotate it so it points more away from the driver, giving that couple of inches extra as legroom in fifth.
So you can mod the steering wheel position or the lever position - whichever works best for your height.
captain
Post by captain » Thu Aug 27, 2015 1:10 pm
mxvx wrote:Is it a blue s1?
Aye...did I see you last night on the a944?
captain
Post by captain » Thu Aug 27, 2015 1:13 pm
Thanks, yes that is a bit of a problem for me too but not insurmountable with a bit of thoughtful hand placement on the wheel. Think I might try a small spacer, I have pretty long arms and the wheel is in a perfect position just now.
mxvx
Post by mxvx » Thu Aug 27, 2015 2:00 pm
Seen a blue s1 in Shell car park this morning around 0730 - guessed that was you?. Sounded good!
Yellow s1 here on a daily basis also with a hard-top, anyone here?
captain
Post by captain » Thu Aug 27, 2015 2:06 pm
Aye that's me! I know the owner of the yellow one, it's a Honda and is getting a turbo soon.
