Wanted
Re: Wanted
Tut mines is up at murrys and getting replaced in the next two weeks could probably use my old ones?
1999 S1 Elise 111S - Fun Spec
Re: Wanted
Only problem Scott is if I had to go to plan B they would not be seen again, hence any condition.
Re: Wanted
Probably not an issue they would have only been kept as a back up if new ones where sent for refurb, if it helps you out it's all good
Re: Wanted
I might have some old konis in the garage you could have. Would need to go searching, will let you know.
Re: Wanted
Thanks Dom, they would be fine as i would need them ASAP before Himself turns up.
Re: Wanted
Think I might have the ones off Lindsay's car or I might have thrown them out. Will let you know Monday.
Re: Wanted
Cheers Scotty.
Re: Wanted
Do you need them in Old Deer or at Murray's? Have a set in Edin.
Re: Wanted
Up at old Deer Ferg.
