Tyre sealant foam (NLC)
Post by j2 lot » Fri Mar 28, 2014 10:28 pm
Got a flat tyre that wouldn't stay inflated after pumping it up with a compressor so had to restore to the foam filler, the puncture was caused by a screw in the tread that snapped off so should be repairable.
Which repairers are most likely to fix tyres that have the foam in them rather than recommend replacement.
duggiesmith
Re: Tyre sealant foam (NLC)
Post by duggiesmith » Sat Mar 29, 2014 12:18 am
I've used Tom Farmer in the past and was pleasantly surprised by the service (tyre sealant hadn't been used though).
Duggie
Aubergine Elise S
Plum Crazy Exige 410 Sport
neil
Post by neil » Sat Mar 29, 2014 9:36 am
I think the reason they can't normally repair them is because they cant see where the puncture was. If it's an obvious screw then I'm sure it's possible.
Exige V6
