HAARP, would love the views of the more technically minded!
Post by mwmackenzie » Tue Feb 18, 2014 11:11 am
Calling Robin and the tech posse!
What do you make of all this Dr Evil stuff.... It's all very Bond!
Copied from Facebook and Wikipedia
t's absolutely fascinating how many people still don't know about HAARP and weather modification. It is almost as if the information does not reach the masses as so many remain completely unaware of what this global military operation is about. We have a few articles about it on our website but it's not a major focus for us right now. Are people in our audience familiar with HAARP and it's capabilities, or should we produce more articles on the topic? Our advice on HAARP is to be aware that it exists, but although very relevant today, there is some evidence coming forward that this project will not be functional in the coming decade. In the meantime, know that the weather you see, whether in front of your window or around the world, may not be naturally occurring at all.
Here's a quick overview:
HAARP is a large 180 antennae grid across the world that projects powerful electromagnetic pulses to heat a specific point in the earth's ionosphere. This has the effect of creating electromagnetic frequencies that can be bounced back to earth at desired locations, causing major disruption to weather and geophysical elements, even deep underground. Up to 3.6 billion watts can be generated by HAARP, heating the ionosphere to over 50,000 degrees and “lifting a 30 square kilometre area of the ionosphere, thereby changing localised pressure systems or even altering the route of jet streams.”
It can create any weather phenomena in almost any part of the world when desired. That includes long periods of drought, torrential rains, flooding, snow storms, ice storms, prolonged warming, prolonged cooling, tornadoes, and many other types of weather patterns.
The frequencies generated can also tap into to the brain frequencies of every living thing, distorting the natural rhythms of which can influence specific areas of the brain.
HAARP can exercise a form of complete “weather control”, a situation bearing a marked similarity to the Monsanto corporation's stated ambition “to control the food chain.” It is noteworthy that there are currently more than 500 ‘climate ready’ genetically modified plant gene patents awaiting licensing approvals in Washington and Brussels. ‘Climate Ready’ GM seeds and plants are promised by their creators to be capable of producing a crop under both flood and drought conditions.
Wiki Says....
The most prominent instrument at the HAARP Station is the Ionospheric Research Instrument (IRI), a high-power radio frequency transmitter facility operating in the high frequency (HF) band. The IRI is used to temporarily excite a limited area of the Ionosphere. Other instruments, such as a VHF and a UHF radar, a fluxgate magnetometer, a digisonde (an ionospheric sounding device), and an induction magnetometer, are used to study the physical processes that occur in the excited region.
Work on the HAARP Station began in 1993. The current working IRI was completed in 2007, and its prime contractor was BAE Systems Advanced Technologies.[1] As of 2008, HAARP had incurred around $250 million in tax-funded construction and operating costs. It was reported to be temporarily shut down in May 2013, awaiting a change of contractors.
HAARP is a target of conspiracy theorists, who claim that it is capable of modifying weather, disabling satellites and exerting mind control over people, and that it is being used as a weapon against terrorists. Such theorists have blamed the program for causing earthquakes, droughts, storms and floods, diseases such as Gulf War Syndrome and Chronic Fatigue Syndrome, the 1996 crash of TWA Flight 800, and the 2003 destruction of the space shuttle Columbia. Commentators and scientists say that proponents of these theories are "uninformed", as most theories put forward fall well outside the abilities of the facility and often outside the scope of natural science
HAARP's main goal is basic science research of the uppermost portion of the atmosphere, termed the ionosphere. Essentially a transition between the atmosphere and the magnetosphere, the ionosphere is where the atmosphere is thin enough that the sun's X-rays and UV rays can reach it, but thick enough that there are still enough molecules present to absorb those rays. Consequently, the ionosphere consists of a rapid increase in density of free electrons, beginning at ~70 km, reaching a peak at ~300 km, and then falling off again as the atmosphere disappears entirely by ~1,000 km. Various aspects of HAARP can study all of the main layers of the ionosphere.
The profile of the ionosphere is highly variable, changing constantly on timescales of minutes, hours, days, seasons, and years. This profile becomes even more complex near Earth's magnetic poles, where the nearly vertical alignment and intensity of earth's magnetic field can cause physical effects like aurorae.
The ionosphere is traditionally very difficult to measure. Balloons cannot reach it because the air is too thin, but satellites cannot orbit there because the air is still too thick. Hence, most experiments on the ionosphere give only small pieces of information. HAARP approaches the study of the ionosphere by following in the footsteps of an ionospheric heater called EISCAT near Tromsø, Norway. There, scientists pioneered exploration of the ionosphere by perturbing it with radio waves in the 2–10 MHz range, and studying how the ionosphere reacts. HAARP performs the same functions but with more power and a more flexible and agile HF beam.
Some of the main scientific findings from HAARP include
Generating very low frequency radio waves by modulated heating of the auroral electrojet, useful because generating VLF waves ordinarily requires gigantic antennas
Generating weak luminous glow (measurable, but below that visible with a naked eye) from absorbing HAARP's signal
Generating extremely low frequency waves in the 0.1 Hz range. These are next to impossible to produce any other way, because the length of a transmit antenna is dictated by the wavelength of the signal it must emit.
Generating whistler-mode VLF signals that enter the magnetosphere and propagate to the other hemisphere, interacting with Van Allen radiation belt particles along the way
VLF remote sensing of the heated ionosphere
Research at the HAARP includes
Plasma line observations
Stimulated electron emission observations
Gyro frequency heating research
Spread F observations (blurring of ionospheric echoes of radio waves due to irregularities in electron density in the F layer)
High velocity trace runs
Airglow observations
Heating induced scintillation observations
VLF and ELF generation observations[6]
Radio observations of meteors
Polar mesospheric summer echoes (PMSE) have been studied, probing the mesosphere using the IRI as a powerful radar, and with a 28 MHz radar, and two VHF radars at 49 MHz and 139 MHz. The presence of multiple radars spanning both HF and VHF bands allows scientists to make comparative measurements that may someday lead to an understanding of the processes that form these elusive phenomena.
Research on extraterrestrial HF radar echos: the Lunar Echo experiment (2008).[7][8]
Testing of Spread Spectrum Transmitters (2009)
Meteor shower impacts on the ionosphere
Response and recovery of the ionosphere from solar flares and geomagnetic storms
The effect of ionospheric disturbances on GPS satellite signal quality
Producing high density plasma clouds in Earth's upper atmosphere[9]
Research done at the HAARP facility has allowed the US military to perfect communications with its fleet of submarines by sending radio signals over long distances.[10][11]
Conspiracy theories[edit]
See also: List of conspiracy theories: Development of weapons technology
HAARP is the subject of numerous conspiracy theories. Various individuals have speculated hidden motives and capabilities to the project, and have blamed it for triggering catastrophes such as floods, droughts, hurricanes, thunderstorms, earthquakes in Iran, Pakistan, Haiti and the Philippines, major power outages, the downing of TWA Flight 800, Gulf War syndrome, and chronic fatigue syndrome.[4][20][21]
Allegations include the following:
A Russian military journal wrote that ionospheric testing would "trigger a cascade of electrons that could flip earth's magnetic poles".[22]
The European Parliament and the Alaska state legislature held hearings about HAARP, the former citing "environmental concerns".[23]
Nick Begich Jr., the son of former U.S. Representative Nick Begich and author of Angels Don't Play This HAARP, has claimed that HAARP could trigger earthquakes and turn the upper atmosphere into a giant lens so that "the sky would literally appear to burn", and maintains a website that claims HAARP is a mind control device.[22][24]
Former Governor of Minnesota and noted conspiracy theorist Jesse Ventura questioned whether the government is using the site to manipulate the weather or to bombard people with mind-controlling radio waves. An Air Force spokeswoman said Ventura made an official request to visit the research station but was rejected-"he and his crew showed up at HAARP anyway and were denied access".[25]
Physicist Bernard Eastlund claimed that HAARP includes technology based on his own patents that has the capability to modify weather and neutralize satellites.[3]
Stanford University professor Umran Inan told Popular Science that weather-control conspiracy theories were “completely uninformed,” explaining that “there’s absolutely nothing we can do to disturb the Earth’s [weather] systems. Even though the power HAARP radiates is very large, it’s minuscule compared with the power of a lightning flash—and there are 50 to 100 lightning flashes every second. HAARP’s intensity is very small.”[3]
Computer scientist David Naiditch characterizes HAARP as "a magnet for conspiracy theorists", saying that HAARP attracts their attention because "its purpose seems deeply mysterious to the scientifically uninformed".[4] Journalist Sharon Weinberger called HAARP "the Moby Dick of conspiracy theories" and said the popularity of conspiracy theories often overshadows the benefits HAARP may provide to the scientific community.[26][27] Austin Baird writing in the Alaska Dispatch said, "What makes HAARP susceptible to conspiracy criticism is simple. The facility doesn't open its doors in the same way as other federally-funded research facilities around the country, and it doesn't go to great efforts to explain the importance of its research to the public."[20]
Says it was shut down in May 2013 awaiting a more Evil Contractor lol... :lol:
Re: HAARP, would love the views of the more technically mind
Post by robin » Tue Feb 18, 2014 11:29 pm
Never heard of it. Suggest wiki is more plausible than the GM-food-mind-altering-weapon nutters :-)
vxc
Post by vxc » Tue Feb 18, 2014 11:33 pm
reminds me of the movie "the core"
Post by campbell » Wed Feb 19, 2014 12:58 am
Er, no. Everyone knows Michael Fish makes the weather.
Post by robin » Wed Feb 19, 2014 9:58 am
campbell wrote:Er, no. Everyone knows Michael Fish makes the weather up.
Fixed that for you.
Post by campbell » Wed Feb 19, 2014 10:16 am
