Duplicate files help. (NLC)
Quick question,
I have a music folder which ,over the years, has become contaminated with duplicate files (thanks itunes). Can anyone recommend a program to weed them out? I've tried a couple but whilst bthey identify dupes they don't seem to realise I want to keep the original. ie they will be of the filnames
<song title>.mp3
<song title> 1.mp3
<song title> 2.mp3
Obviously it's the second 2 I want shot of. They all have the same creation date etc so the only way to do it manually is CTRL select which will take a while... (6000 duplicate files).
<song title>.mp3
<song title> 1.mp3
<song title> 2.mp3
'99 - '03 Titanium S1 111S.
'11 - '17 S2 135R
'17 - '19 S2 Exige S+
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
Re: Duplicate files help. (NLC)
To list:
ls $(find /home/pete/Music -type f -name "*[0-9].mp3")
To delete:
rm $(find /home/pete/Music -type f -name "*[0-9].mp3")
Obviously replace /home/pete/Music with whatever your library path is.
If you're using windoze then you can download MSYS here - http://www.mingw.org/wiki/MSYS
Then open an MSYS shell and use the above commands.
To delete:
Cheers Robin, it's actually on a Freenas box (dunno whose suggestion that was) but I access it through windows...
I'll try your suggestion tonight.
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
OK,
Assuming you can ssh login to the FreeNAS box (which is probably running BSD?) you should be able to run those commands as is ... I suggest you use the listing version first in case it selects files you don't want to delete.
If you want to run teamviewer on your PC we can connect through 'tinternet and I can show you what to do ...
robin wrote:OK,
Thanks Robin I'll try and work it out myself first. Well me and The Google.
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
I knew that Computer Science O level would come in useful one day. 6 hours in and I think I've found the command line.
Oh.
It's crashed.
Maybe it's just working really hard.
Oh.
It's crashed.
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
It's working!
I think!
I think!
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
Argument list is too long apparently. But it's still a big step so I'm off for a bit of a celebratory lie down.
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
To list without hitting long argument list:
find /home/pete/Music -type f -name "*[0-9].mp3" | xargs ls
Or to remove:
find /home/pete/Music -type f -name "*[0-9].mp3" | xargs rm
Or to remove:
That is an awful lot of duplicate porn files Pete.......
I didn't know you'd done so much work. You're very talented.tut wrote:That is an awful lot of duplicate porn files Pete.......![]()
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
robin wrote:To list without hitting long argument list:
Or to remove:
This command line stuff is fantastic. I mean I haven't actually got it to work yet but it is MUCH better than all that picture malarky.
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
What's not working? Cut and paste the screen and email it to me, if you like: robiniddon@gmail.com
Thanks for the help last night Sir.
All sorted now.
All sorted now.
'11 - '17 S2 135R
'23 - ?? Evora
'11 - '17 S2 135R
'23 - ?? Evora
