Need to sort out a computer which has to be housed inside a transit style suitcase for work and wondered if anyone on here could point me in the right direction?
Essentially Im looking to combine some electronics inside a case which also houses a PC but the thing is I need it at least IP54.
Ideally a case which opens and has a panel style PC/monitor in the lid with a keyboard mouse setup on the flat. Underneath the Keyboard I need around 100 mm of depth 500 length and 400 width.
Internal electronics will be using around 80 watts which along with power supplies will generate quite a lot of heat. A company that could mould a case around a heat sink would be ideal as this deals with mounting also. We wont be talking big numbers so understand costs will be high but would be nice to have a few options.
Found a company that can make something for me but are looking for nearly 5 figures! Any suggestions of alternative companies who already do this kind of thing or even someone I could start talking to?
