by tut » Fri Oct 11, 2013 1:23 pm
Andy, make sure that you have the latest master box from BT which has internet and phone sockets without a splitter. After my first set of problems they fitted it, but the actual cause was the Exchange equipment, seems that the engineer set it at a 15db rate instead of 5.
The last problems were an increasing number of dropouts over a three week period, ending up with no connection at all. They cured the initial one by changing the channel number, but then we had what they said was a major outage for Mintlaw and Peterhead areas, it was supposed to be fixed after a couple of hours, but I was without for two days. Will give the support staff in Mumbai a big thumbs up though, good English, very polite and patient, and could not do enough to help and try and sort it out.
However they could not know that they had to contend with numbnuts at this end who could not trace the fault to the equipment in the Exchange for two days, once this was changed I was back on line. Pretty obvious as I had a connection to my router, but no internet connection. I get a 6-8mb connection, which considering I am on the lowest of the low configs, old copper cable fed by a non LLU Exchange, is pretty good. Can watch utube, video and iPlayer in HD.
However I will be ditching them when my contract is up, they were charging me £26/month for Broadband alone, which I got reduced to £16 after telling a Supervisor they were a bunch of robbing barsteward, to which he agreed. Will change the whole package over to Sky at £2.50 for unlimited.
