video in cars :- attention gadget guys
Lawrence
Post by Lawrence » Mon Sep 18, 2006 9:25 pm
My video camcorder is acting up, tape jam or similar is it possible to have them repaired or serviced? It's a Canon MV5i
failing that does anyone have any info on solid state recorders?
all I've found so far is Neuros Recorder 2
Anybody have one?
Post by Andy G » Mon Sep 18, 2006 9:26 pm
archos make the av500 or Sanya and JVC make them also.
Only have tried the Archos though
Post by Mr Momo » Mon Sep 18, 2006 9:26 pm
My sony miniDV had same problem - fixed for about £80 (Sony Centre). Will need to by a new HD/MiniDV to play the old tapes when it gives up.
Post by alicrozier » Mon Sep 18, 2006 9:33 pm
I can lend you my Samsung titchy camcorder if you're stuck...
It has AV in.
Might save some weight, 150g. ;)
Post by mac » Mon Sep 18, 2006 9:55 pm
Lawrence,
have a chat with Simon Ironside :wink:
Lawrence
Post by Lawrence » Mon Sep 18, 2006 10:01 pm
Andy G wrote:archos make the av500 or Sanya and JVC make them also.
Andy
Are these not hard drives?
Lawrence
Mr Momo wrote:My sony miniDV had same problem - fixed for about £80 (Sony Centre). Will need to by a new HD/MiniDV to play the old tapes when it gives up.
So who fixes Canon?
Lawrence
Post by Lawrence » Mon Sep 18, 2006 10:04 pm
alicrozier wrote:I can lend you my Samsung titchy camcorder if you're stuck...
It has AV in.
150 grams ??
my remote is 110g and 500 for the camcorder
what model is it Ali?
Lawrence
mac wrote:Lawrence,
Shall I pm him?
Post by mac » Mon Sep 18, 2006 10:09 pm
Could do, but I'm not sure if his "project" would be of any use?
ironside
Post by ironside » Mon Sep 18, 2006 10:13 pm
I was/am working on something that can record from multiple bullet cams, but it's been a bit of a let down so far :(
Too slow to record at any decent rate/resolution from more than one camera.
Simon
Post by Andy G » Tue Sep 19, 2006 7:56 am
Andy
Quite true. The problem with recording to flash is there still isn't anything that will hold a decent amount at a decent resolution. The archos currently has about 55 track day clips on it.
Post by alicrozier » Tue Sep 19, 2006 8:39 am
It has AV in.
150 grams ??
It's the old version of this (with only 1Gig fixed memory):
http://www.samsung.com/uk/products/camc ... 20lxeu.asp
All my vids are taken with it (the resolution is reduced for the web):
http://www.putfile.com/alicrozier
My issues with it are battery life and recording time for trackdays. Limited to 45 mins really with the battery and 25 mins or so with the very highest recording quality (with base 1Gig memory). Would be OK for hillclimbs. :)
As I said you're welcome to a shottie. :)
Lawrence
Post by Lawrence » Tue Sep 19, 2006 8:57 am
cheers Ali
I've just been confirmed for Alford on Saturday 7th so could see you there :) perhaps
Post by alicrozier » Tue Sep 19, 2006 9:21 am
Lawrence wrote:
cheers Ali
Sounds good, I'll make sure it's charged up etc. and come along early to set it up. :)
