Wanted urgently.
Wanted urgently.
Post by tut » Mon Apr 01, 2013 8:15 am
Does anybody have a used S1 wheel hub flange that they would not be using in the near future?
My car is stuck on John's ramp so need a replacement ASAP.
cheers
Re: Wanted urgently.
Post by woody » Mon Apr 01, 2013 8:19 am
Tut, I have two 43k miles MG TF rear suspension arm assemblies with shafts here. There will be a flange in each if you want it (the S1 uses the same flanges).
Post by Scotty C » Mon Apr 01, 2013 9:10 am
didn't Lowell (Foz 01) offer you one on another tread?
if you need his number then give me a shout.
Post by tut » Mon Apr 01, 2013 1:29 pm
Cheers Scotty had forgotten, but just replied.
That would be the best solution, replace the hub carrier in one.
Post by Scotty C » Mon Apr 01, 2013 1:58 pm
think i will be up to see you on Wednesday if you need it brought up :thumbsup
Post by tut » Mon Apr 01, 2013 3:22 pm
That would be ideal, will try and arrange it with Lowell.
Post by tut » Mon Apr 01, 2013 7:52 pm
Try not to get old.......
Stirrings of memory came up with images of hub carriers and brake calipers. However even in my garage Verian can not stand seeing something in view which is the way that men do it, so buys multicoloured plastic boxes that she hides them away in.
As a result I found eight sets of Powerflex wishbone bushes, two rear left and right ali hub carriers complete with bearings and hub flanges, and in great nick, and various light switches. Also two front brake calipers and one rear, eight new ball joints, a new headlight and driving light, and loads of bulbs, some high powered Phillips.
Thanks to all for offers of help, much appreciated, but now means I can take everything down to John first thing in the morning, and get N3 back on the road.
foz01
Post by foz01 » Mon Apr 01, 2013 9:33 pm
Glad you got sorted, I need to do a clear out to be honest, got loads of stuff I need to shift :)
Motorsport K20 Elise
Wanted urgently.
Post by Sanjøy » Mon Apr 01, 2013 10:12 pm
Inventory .xls in google docs so you have it available when at a track and shareable.
2p
